brake pad question
Old Sep 16, 2010 | 09:25 AM
Zalley's Avatar
brake pad question
anyone used oreilly's wagner pads? I get them for 60 buck for all pads and am on a super tight budget , I got my rotors turned for free , so that was lucky , but now I am not sure on NAPA pads or wagner oreilly pads , both are about 60$ for all 4 anyone have any personal experiece>?
also do I need a hardware kit or anything? someone said that I did and the brakes how to is not working. I only have done brakes on honda's before and its just put in new pad , put on rotor , bolt back up and bleed and done.
also has anyone use any autobleeders? I will be doing this by myself and thought about renting a bleeder from autozone since it costs virtually nothing.
Old Sep 16, 2010 | 11:00 AM
Zalley's Avatar
dang I was hoping to do these tonight , feel free to answer one or more of the questions I asked if you only know the answer to one thats cool too I just need the info =P
Old Sep 16, 2010 | 11:51 AM
njmaxseltd's Avatar
Are those Wagners the Thermo Quiet Stop pads? If so, yes they are good, I've run them, the rear set is still on the car. Had to replace the fronts after about 35K miles.
I have them on my Explorer as well, no issues at all.
Old Sep 16, 2010 | 11:57 AM
Zalley's Avatar
sweeet what about the so called hardware?
Old Sep 16, 2010 | 12:13 PM
plugeye's Avatar
didnt need any hardware for my 99.
get some brake cleaner, brake fluid, disc brake lube, wire hanger & a big c-clamp
Old Sep 16, 2010 | 12:53 PM
Zalley's Avatar
c clamp?
Old Sep 16, 2010 | 01:40 PM
njmaxseltd's Avatar
To push the pistons on the front calipers back in.
Old Sep 16, 2010 | 01:43 PM
njmaxseltd's Avatar
You should also flush the brake fluid. It's hydroscopic (absorbs moisture) and degrades over time. It should be changed every time you do a brake job. Also make sure you clean and lube the guide pins. Brakes are easy, just take your time and do them right!
Old Sep 17, 2010 | 02:59 PM
TravisCadello's Avatar
the duralast gold ceramic pads are better and cheaper man from autozone they grab the hell out the rotor and very little dust.
Old Sep 17, 2010 | 03:08 PM
For $60, you could pretty much get really good pads such as the Hawk HPS. However, you'd have to wait to have them shipped to you....
Old Sep 17, 2010 | 05:40 PM
DennisMik's Avatar
I've used wagner brake pads for years, now that I'm in Texas I get them at O'Reilly's. The work fine for my driving which is harder than average. One tool you will need is for the rear calipers - you have to screw them back in, not push them.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
