Front Sway Bar Question
Old Sep 26, 2010 | 10:46 AM
maxima168's Avatar
Is the Front Sway bar suppose to be bolted on tight or should there be some play, so the bar can move while taking corners?
Old Sep 26, 2010 | 11:06 AM
mdliber's Avatar
no sway needed, should be bolted right on solid
Old Sep 26, 2010 | 11:43 AM
cartman854's Avatar
No Play.
Old Sep 26, 2010 | 12:00 PM
neocry's Avatar
Make it tight.
What type of front sway bar did you get? Aftermarket or OEM?
Old Sep 26, 2010 | 12:14 PM
SteveB123's Avatar
The bar should move when hitting bumps with both wheels.
Old Sep 28, 2010 | 07:46 AM
90stanza's Avatar
are you talking about a front strut bar? or sway bar? either way they both should not have any play.
Old Sep 28, 2010 | 08:03 AM
JNCoRacer's Avatar
Just the tip.
I hear you gain some turning radius by removing the sway bar.
Old Sep 28, 2010 | 11:36 AM
njmaxseltd's Avatar
That and a few seconds in the qtr. from less weight.
Old Sep 28, 2010 | 04:23 PM
ColombianMax's Avatar
PLUS you get 2 extre MPGs due to less weight as well
Old Sep 29, 2010 | 05:01 PM
96i30azn's Avatar
On the minus side, you'll gain 2mm of front ride height due to weight.
Old Sep 29, 2010 | 08:00 PM
back2basics's Avatar
Not to mention that of course your cornering will be affected, which is the most important thing to begin with.
You will have more body roll which projects more weight onto the loaded tire under cornering loads and will make it lose traction that much faster.
HOKUSMAX
Nov 13, 2017 04:34 AM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
