retrofit question
you should read more on this if you cannot figure this out. go to the www.hidplanet.com forums and check the university section; many good wiring threads there
Are you going to stick with halogen bulbs?? You could get H7 to D2S adapters and use OEM HID bulbs. With this the wiring shouldn't be a problem because you can use a wiring harness to power the ballast and amp to D2S adapters to power the bulb.
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
