'97 SE CEL Light
Old Oct 5, 2010 | 12:39 PM
sanford7575's Avatar
'97 SE CEL Light
Good Day All,
I have a '97SE in which I just replaced the starter.
After replacing the starter, the CEL now stays on all of the time.
I read the stickies, and checked the codes, and I got 0304 and 0401.
I believe that these indicate the knock sensor and the air intake sensor?
The car drives perfectly. How critical are these sensors to everyday driving? I attempted to reset the CEL, but no dice. Do I have to replace these sensors for the CEl to go off? Does anyone have a reset procedure that will turn the CEL off? I''m guessing that the air intake sensor is cake to change and only $21 at RockAuto, but what about the knock sensor? It's around $70 at RockAuto and I have no clue where it is.
Any advice is greatly appreciated
Old Oct 5, 2010 | 12:49 PM
MaximaSpd85's Avatar
when you moved everything out of the way to replace your starter, did you plug the intake sensor back up? or maybe you started the car without it plugged up once? anyways, if it is plugged up now, and its good, the code should go away after it goes through its drive cycles hopefully. but just because the light goes off, doesnt mean the knock sensor code went away because it actually doesnt make the check engine light turn on.
anyways, the intake sensor, i dont think its gonna affect daily driving in any way really. the knock sensor is robbing you of 20+ wheel horse power, maybe more, and its killing your gas mileage. other than that, driveability will probably feel the same. its underneath the lower intake manifold. if youre good, u can change it the "improper" way in 15 minutes or less.
Old Oct 5, 2010 | 07:27 PM
DennisMik's Avatar
To turn off the CEL light, watch Pmohr's video, link below. If you still have the problem, the CEL light will come back on when you start the car. The knock sensor code does not cause the cel light to turn on. Many times the knock sensor code shows up as a "ghost code" with another code, so fix the air intake code and most likely the knock sensor code will be gone.
http://www.youtube.com/view_play_lis...E3C3345DC2C64F
Old Oct 21, 2010 | 01:55 PM
732vqmqx's Avatar
whats a ghost code? i got a knock sensor code once. i fixed it and cleared the code and it stayed off
Old Oct 21, 2010 | 02:01 PM
jholley's Avatar
A ghost code is a code that does not turn the CEL light on.
Using the SEARCH tool will get you these simple answers.
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxie40
Sep 14, 2015 11:28 AM
ballerchris510
Sep 10, 2015 09:35 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
A32goldylocks
Sep 2, 2015 06:39 AM
