Tending do my misfire and found this!!!
Old Oct 7, 2010 | 05:19 PM
ProW649's Avatar
took a few pics of my coil and plug after i pulled them baffled by what i saw....I know this cant be normal
this is the socket after i pulled it out wit the plug....
was worst b4 i took the picture if you look on the table you can see the ring it left...i have a cold so i tried smellin it 2 see wat it was and couldnt tell
Here's the spark plug after i cleaned it off wit a rag...
the coil...
frnt view...
My question is what caused this and is there any chance the others are the same?
Thnks
-W!nce
Old Oct 7, 2010 | 05:24 PM
mista0406's Avatar
Wow... well how long were driving with misfires? that **** looks bad man.
Old Oct 7, 2010 | 05:30 PM
ampire's Avatar
valve cover gasket seals?
ProW649's Avatar
little over a month
Old Oct 7, 2010 | 05:46 PM
JNCoRacer's Avatar
Just the tip.
Bad spark plug guide tube seals. I had the same problem. $50 for a valve cover gasket kit, changed them out, over a year later and all is good.
Old Oct 7, 2010 | 08:55 PM
DennisMik's Avatar
+1
Old Oct 7, 2010 | 11:01 PM
ProW649's Avatar
thnks for the info
Old Oct 8, 2010 | 05:01 AM
Trini Boom's Avatar
Definitely have your work cut out for you. That looks like its coming from the rear valve cover so you will need the valve cover gasket and spark plug tube seals.
Old Oct 8, 2010 | 05:08 AM
phatboislim's Avatar
x2. you should be all good after you replace that rear valve cover gasket w/ all the components in the gasket kit
Old Oct 8, 2010 | 09:37 AM
asand1's Avatar
Youll also need new coil boots. the hot oil has killed the rubber and your misfire is the boot leaking spark to the tube.
Old Oct 8, 2010 | 10:09 AM
cashoit's Avatar
Old Oct 8, 2010 | 06:44 PM
ProW649's Avatar
so i found an 00vi today sitting in my Uncle's garage (what are the odds??) and decided y not jus do everything in one shot, save a couple bills, new coils, plugs, injectors and gasket set!!
Old Oct 8, 2010 | 06:49 PM
SiathLinux's Avatar
+1 for this being the issue...
Old Oct 9, 2010 | 08:58 AM
JNCoRacer's Avatar
Just the tip.
What luck! It would still be a good idea to get a gasket kit and replace them for the 00vi swap.
Old Nov 12, 2010 | 10:34 AM
ProW649's Avatar
the gaskets are the same right?
Old Nov 12, 2010 | 12:21 PM
FallenOne's Avatar
Valve cover gaskets? Yes IIRC.
Old Nov 13, 2010 | 09:33 AM
wirelessdude04's Avatar
WOW!! Never seen that before
Old Nov 13, 2010 | 10:28 PM
cartman854's Avatar
Common Problem. I fixed and gave me a reason to install NWP Spacers and a MEVI.
Old Nov 13, 2010 | 11:50 PM
elementalg20's Avatar
If I had a dollar for everytime a honda F22 did that to me i'd have $4......
Glad you posted this though as I'm going to have to take a look at mine tomorrow although I think I'm ok it sure wouldnt hurt to look, and check the plugs. Damn I need to go back to the salvage yard to pick apart that 97'......
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
zmcneely13
Sep 26, 2015 02:26 PM
