coil replacement procedure
when replacing the coil pack does Nissan say to use dieelectric grease on the boot or on the top of the plug?
is dieelectric conductive? seems it would not be a good idea to use it?
Dielectric grease is a non-conductive, silicone grease designed to seal out moisture and, therefore, prevent corrosion on electrical connectors. Being non-conductive, it does not enhance the flow of electrical current. This property makes it an ideal lubricant and sealant for the rubber portions of electrical connectors.
If you use it, place a little on the plug BELOW the top metal conductor, it will allow the boot to slide on easier and not be stuck the next time you change the plugs. Don't get any on the metal part of the plug
vingodine
45
May 21, 2016 12:46 PM
kenc15
Sep 25, 2015 06:38 AM
evonder73
Sep 1, 2015 02:21 PM
