Rev limiter??? dropping into 3rd gear @ 110
Dec 17, 2001 | 05:04 PM
The rev limiter only kicks in if you are running up through the gears? Correct? I'm wondering ... my car doesn't sound good and I accidentally shifted into 3rd doing 110mph... (just sounds like its running a little rought, not shaking or anything) I HOPE IT HIT THE Rev-limiter, but I wasn't looking? So. am I correct, that downshifting doesn't allow the rev limiter to go into affect and that there could be some serious damage to my car?
Scott
Dec 17, 2001 | 05:14 PM
Sure, it probably hit the rev limiter. But way too late.
Dec 17, 2001 | 08:03 PM
If you miss a shift (hit a low gear) at that kind of speed, the rev. limiter ain't gonna help you much, unfortunately.
An ignition-cutout type rev. limiter really only works "on the way up," not "on the way down."
It is very possible to exceed the redline and do damage to your engine if you hit too low a gear, regardless of whether the ignition rev. limiter kicks in or not.
This is because the rotational inertia of all those engine parts moving (when you release the clutch & mate up that wheelspeed to the driveline in the low gear) is just too great for the ignition-cutout to slow all that movement.
Be veeeerrrry careful. Snap, crackle & pop, are sounds best left to breakfast cereals, not your Maxima's powerplant.
Dec 17, 2001 | 08:47 PM
ask emax95 about going from 3-2 at 95
Dec 17, 2001 | 09:21 PM
Quote:
OUCH. I feel pain through my car. That sounds like it would hurt.
Dec 17, 2001 | 11:37 PM
Ooops. That's not fourth gear!
"Hey, why are they all walking back?"
Dec 18, 2001 | 04:42 AM
hehehehehehehehe
Dec 18, 2001 | 04:44 AM
What types of sounds should i be listening out for? Snap, crackel, pop??? It seems to be ideling a little rougher that it did before?
Dec 18, 2001 | 10:14 AM
Ohh it did . Then add a good 10 SI of Super charged power into the mix, you get one very blown up clutch. Luckly the clutch blew and not my engine or tranny, thank god.
Dec 18, 2001 | 01:10 PM
well if it is idling bad you better go to a shop and get it checked out. I went from fourth to second doing over 100 in my nissan pickup and it bent 3 valves and chip the timing chain.
Dec 18, 2001 | 01:33 PM
110 in third aint tooooo bad. Most NA Max'x finish the 1/4 mile at just under 95mph. So you probably spun it up to ~7500-8000k. Id drive it a little while and see how it feels.
Dec 18, 2001 | 02:32 PM
Quote:
8000RPM!!!! THats not to bad!! Thats mega redline!
BUt wait, doesnt an auto do 110 in 3rd?? Mine does
Dec 18, 2001 | 02:33 PM
ya but it's not close to 10k rpms like a 3-2 at 95 would be
Dec 18, 2001 | 02:41 PM
Dec 18, 2001 | 04:40 PM
Been there, done that...racing downhill, I misshifted from 3-2 at redline. Don't ask me how, I was new at stick then
No damage, though, I was lucky.
Dec 18, 2001 | 05:26 PM
It went right off the guage? Isnt there a stop stick there?
Dec 18, 2001 | 06:46 PM
around 8 or so something usually gives and boom.
