How often should I change the transmission fluid
Just wondering on how often I should change the transmission fluid in my '95 SE Auto. I did a search and they said I should not change it at all. The last time my trans fluid was changed was at 98,717. I currently have 130,767. I talked to the service rep and he said I should not change it at all...something about the debris helps shift the trans. Any advise.
Re: How often should I change the transmission fluid
I do a drain and refill every oil change (6,000 miles) (regardless). Although it may be clean heat can destroy and or break down the protective properties of the fluid, thus turning the tables on your tranny.I also clean the pan/new gasket/new filter screen once a year. Also you might want to replace your drain plug, and change your anti-freeze(use distill water) more often, in addition you might want to try some Redline water wetter (coolant additive), whereas it helps keep high temps down. I flush/dump my antifreeze every 6 months, you can't beat the protection and costs. Good luck! 96se,Dunlop SP 5000's, Amsoil 0w-30, 156,000 plus miles (original tranny).
http://forums.maxima.org/showthread....threadid=77101
I discuss ATF replacement in there.....
Re: Re: How often should I change the transmission fluid
Originally posted by bill99gxe
My advice is to read the link below:
For the lazy people....
That basically says that you should not use any conventional Automatic transmission Fluid for more then 30,000 miles....
Which is about 32k more then I've driven on mine Time to flush my ATF
Changing the tranny fluid is like changing oil, it should be changed. Car with high mileages usually shouldnt be changed ... or so they say. I change my fluid every 15k miles since i do a lot of local driving and hit the drag strip a lot. If you do mostly highway, change it about every 30k since it wont heat up as much as city driving would.
Just changed my '99's at 33000 miles.
Thought I felt the overdrive gear shift more abruptly for a short while but seems fine now.
I remember changing the oil on an '85 escort years ago.
the escort had 45000 miles on it and after the trans oil change the trans started slipping.$1000 later...
the new oil did too good of a job in cleaning the clutches.
I was told by many to either change often or not at all.
I waited till 33000 because I just decided to buy my lease after getting a bundle off my residual.
Felt her shifting at 35-40 a little rougher.
I thought I was screwed but am very happy she's back to normal.
I changed my 98 auto tranny fluid at 50K. Went to my mechanic yesterday for an oil change and he said that my trany fluid looked dark already (now at 65K). Lately my shifts from 1 to 2 has been very rough, so he flushed it completely and changed it. I think it helped. My shift are much smoother. I say change it at least every 30K. After 60k, I think you are suppose to according to Nissan.
My 0.02
C
My 0.02
C
I change my ATF every 3rd oil change, which to some people is very ****, but I just like to know that I'm running clean and confident especially with the trannsmission cooler installed. To this day I have 102K miles and the tranny has like new smooth shifts. Could it be the tranny cooler, or the drain and refills? I certainly hope it's one of them. I've heard many people say it is not safe to do the drain and refill or "flush" with high mileage cars that are already past due.
How late is too late??
Should I do it or not??
Has anybody actually read the Oil Analysis sticky where ATF replacement and lab-backed recommendations are given, or are you all more interested in re-inventing the wheel?
Good heavens, people:
Re: How late is too late??
Originally posted by nizmo
How many miles is too late to change ur transmission fluid. I have a 95 SE 5spd and the shifts arent that smooth. I heard from people that Redline Transmission fluid makes a difference. I was planning on doing that but my car has around 76500 miles so I dunno if I should do that.
Re: Re: How late is too late??
Originally posted by BenBlanco218
I actually did my first drain and refill at 80K miles, and made the biggest difference in smooth shifts. Now I heard a true "flush" could shock the tranny so drain and refills would be better which only drains about half the tranny fluid so do the drain and refill about 3-4 times to gradually so get it clean.
I took a look at the spreadsheet and not being a techie, I did not understand it at all. If someone would be so kind enough to decipher it for me, that would be great. Put it in layman’s terms. I have a supra and take care of it religiously so I am trying to do the same with the max but I just bought the car with 115K. I am actually backtracking to see what service has been done. Therefore with the following replies, I think I will just drain and refill without flushing.
Thanks guys.
Thanks guys.
Re: Re: Re: How late is too late??
Originally posted by mlocke
From reading other posts, there's about 10 qts total and about 4 qts can be drained. If I'm doing my math correctly, it will take 4 drain and fill cycles to get about 87% new / 13% old fluid.
Re: Re: Re: Re: How late is too late??
Your right, that's why I have been drain and refilling for the past few oil changes, and after every oil change my fluid tends look more reddish and cleaner.
SuDZ
Some confusion??
I think there may be a little confusipon here. Some auto maxima guys are giving advice to 5 speeders and vice versa. The tranny fluid change between auto and 5 speed maximas are quite different.
Here's the break down;
Autos, generally change the tranny fluid every 30K or so miles. The tranny fluid in an auto works MUCH harder than the tranny fluid in a 5 speeds.
5 speeds, if you don't tow a camper or anything like that, then you NEVER have to change your fluid. Now, the stock tranny fluid on the 5 speed is only adequate in terms of good feel, like cold mornings when you just can't get it into 1st etc. Try Red-line MT90. You can change it any time. I did mine at 60K miles. Just like an oil change, you drop the old fluid and fill up with the new fluid.
That's all.
DW
That's all.
DW
sctludwig
09-01-2022 01:32 PM
