My CAI makes a noise
Old Dec 17, 2001 | 06:43 PM
Fish254's Avatar
when rpms are about 2000 the CAI makes hising noise is that noraml for it to do it?
Old Dec 17, 2001 | 06:49 PM
Greg's2kGLE's Avatar
Re: My CAI makes a noise
I think it is just making that sound because it's sucking air in. My "pop-charger" makes the same sound.
Old Dec 17, 2001 | 07:51 PM
AznStevie's Avatar
haha...
when my car idles..u can hear that hiss from a far away place hehe..
Old Dec 17, 2001 | 07:53 PM
black97max's Avatar
The hissing is normal.
Old Dec 17, 2001 | 10:12 PM
krzymax's Avatar
Maxima owner since 2000
i would be worrying if your CAI didn't make a sound.
Old Dec 17, 2001 | 11:22 PM
sbslacker's Avatar
Hmmm..
My CAI makes a strange noise...it gets louder as I accelerate more (esp when car is cold), but it's not the normal sucking noise of air coming up the tube. It's more of a rattling noise that I hear from the center air vents on my dash. It's not a metallic type noise or anything. It's like the filter or tube is rattling aginst something, but it's an on again, off again type of thing. Any ideas? I know, really vague...sorry
Luke
99 SEL
Old Dec 17, 2001 | 11:33 PM
NmexMAX's Avatar
dot dot dot ...
The CAI has a more pronounced hissing than the JWT/Stillen Intake because of the CAI's upper intake tube portion, which eliminates the top resonator that the SI/JWT POP doesn't.
As far as the rattling vents noise deal, I don't know, so vaguely, your CAI is making plastic vent-like noises? Hmm, something is definately loose
Old Dec 18, 2001 | 07:37 AM
breaux124's Avatar
The hissing at that rpm is normal.
Just double check everything to make sure that all the clamps are tight. Everyone with the CAI has that hissing, so don't worry.
Old Dec 18, 2001 | 07:50 AM
BRIGBOY's Avatar
Re: Hmmm..
Luke
99 SEL
Is your hole too big? Seriously, It might be vibrating against the hole. I used a 3.5 inch hole saw, made the hole too big, caused a noise similar to what you describe, and had to line it with extra padding.
Old Dec 18, 2001 | 07:56 AM
Sprint's Avatar
sometimes mine sounds like a turbo .. ask the guys at the woodbury meet..
Old Dec 18, 2001 | 10:02 AM
sbslacker's Avatar
Re: Re: Hmmm..
I used a 3.25" hole saw...isn't that what the instructions tell you to do? The tube does move just slightly as it protrudes through it though....maybe that's it. I'll get some thicker rubber lining for the hole to secure the tube better and see if that works.
Luke
99 SEL
Old Dec 18, 2001 | 10:05 AM
99maxi's Avatar
my hole is a little small and when i step on the gas i here the CAI move. it is rubbing against the little rubber lining, and gives a tick sound when the engine moves. i need to get some rubber lining to fasten the CAI better, but it is too cold to do it now.
sbslacker's Avatar
Yeah, it's really sporadic sometimes. As my RPM's increase the 'rattle' gets louder...then the transmission shifts, and it stops. I've looked under the hood numerous times but can't find anything that is suspect.
Luke
99 SEL
Old Dec 19, 2001 | 10:18 PM
NISMOPower's Avatar
Intresting how did you drill the hole? Specifically...I wanna sound like a turbo...heehee...
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
