Squealing under Hood
Old Nov 23, 2010 | 12:03 PM
Lyoko's Avatar
There is a mild squealing noise coming from under my hood. Funny thing is it only makes this noise once every few drives. I am assuming this is some sort of belt that needs to be replaced. What belt will I inspect and most likely replace?
Thanks.
In my reasearch, I am coming across the term "Serpentine Belt". Is this what I am looking for?
Old Nov 23, 2010 | 12:54 PM
pavelsmax's Avatar
Most likely the squeal is coming from a belt that has loosened up over time or worn out. We have 2 belts on our cars.
Here's a link on how to check them. Search and you will find a how to on replacing them.
http://www.greghome.com/images/Maxim...DriveBelts.jpg
Old Nov 23, 2010 | 12:56 PM
Lyoko's Avatar
Thanks!
Old Nov 23, 2010 | 02:22 PM
asand1's Avatar
Could also be the idler/tensioner bearing squeeling. I've found a bearing that can be pressed into the old wheel for $2.70 +free shipping on the bay.
Old Nov 23, 2010 | 07:34 PM
DennisMik's Avatar
A belt is the most common, but bearings can do it. My car developed a squeal and it turned out to be the altenator.
Old Nov 26, 2010 | 08:44 PM
El_BoriMax's Avatar
The alternator how? cuz im having a loud squeeling noise when of course start the car and sometimes driving. I tried tighting the belt but not powering steering belt. How you found out it was the alternator? Its getting annoying as hell.
Old Nov 26, 2010 | 09:01 PM
MaxJammin's Avatar
im having the same problem...it only developed once i installed my 1000W amp and subs, im assuming my problem is my alt, but the easy way is to check tension on both belts, and, even thought ill catch hell for this, i used a little 800 grit sandpaper to treat the belt(s)(de-glaze it(them))
Old Nov 27, 2010 | 12:39 AM
SupaDoopa's Avatar
Sounds like belts. Either need replacing or to be tightened.
Old Nov 28, 2010 | 07:06 PM
MaxJammin's Avatar
update!, replaces battery terminals, and tightened the belt, and the squealing stopped, also discovered my battery was cracked badly and the one cell had gone dry, all in all, i believe that the belt tightening did the trick
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
