another "birds chiripin under the hood"
Old Nov 30, 2010 | 11:20 PM
tsheffler's Avatar
so..it started yesterday morning...started the car and heard what sounded like chirping under the hood, its obviously coming from the area around the belts..
- my crank puley vibrates at idle...but its done that since i got the car a year ago... my belt was loose months ago, tightened it, *squeel* gone, but this is chirping, sounds like birds under my hood,when i rev it, it just gets faster and a little higher pitch, but dies down to a constant chirp at idle, i did research on it but coulldnt find anything to narrow it down enough...:/...tomorow i will see if my crank pulley is loose to the touch and will try tightening it when everything is torn apart for my clutch.
- ive read about maybe bearings, water pump, or just a bad pulley in itself, any advise is helpful thanks!
Old Dec 1, 2010 | 06:46 AM
sonicrunch's Avatar
maybe you have birds under your hood :dunno:
Most likely a bearing. Most likely an alternator bearing. Do you have a mechanic's stethoscope?
Old Dec 1, 2010 | 08:23 AM
cartman854's Avatar
So did you kill the birds?
Old Dec 1, 2010 | 09:34 AM
asand1's Avatar
Thought;
Idler/tensioner bearing
alt bearing
crank pulley seperating
AC or PS
Old Dec 1, 2010 | 09:35 AM
bobflood's Avatar
Also could be bearing in tensioner pulley.
Old Dec 1, 2010 | 11:00 AM
tsheffler's Avatar
1. is there a way to check to see if the pully is going? other than taking the belt off, spinning each individual pulley to see if it squeaks?
2...and yea you know i kill the birds and stick them in my sub box to make it bump harder, literally....haha no
Old Dec 2, 2010 | 02:37 AM
dkillahster's Avatar
hmm... maybe you can try taking some ajax and sprinkling it around the pulleys and see if the chirping stops? well, that always helped me..
Old Dec 2, 2010 | 07:32 AM
RA021526's Avatar
So, the belt isn't loose?
Old Dec 4, 2010 | 06:08 PM
El_BoriMax's Avatar
Well when I turn on my hids I def get the squeaking noise. Do you I might need to change the alternator and the belt?
Old Dec 4, 2010 | 06:48 PM
RA021526's Avatar
Ok. You have to actually check things before we can give you an answer. In all likeliness, your belt needs to be tightened. It could also be worn out, so inspect it for cracks or wear and replace if necessary.
AdMax98
May 14, 2002 04:41 AM
metallic97gxe
May 2, 2002 08:49 PM
mike-777
Aug 10, 2001 12:05 PM
[maxi-overdose]
Jun 7, 2001 07:15 AM
Omegasrk
Feb 22, 2001 10:16 AM
