Mufler/Exhaust Bolt Question - Size?
Old Dec 18, 2010 | 07:08 AM
KidA157's Avatar
Does anybody know how what type/size bolts I should be using to connect the muffler to the exhaust piping? I would typically have the old bolts to base this off of, but the bolts actually rusted apart and broke causing the muffler to fall off in my driveway...
Thanks guys!
Old Dec 18, 2010 | 07:23 AM
ampire's Avatar
I would just take the muffler into lowes and buy some standard bolts that fit through the two holes, some lock washers, some nuts.
Old Dec 18, 2010 | 11:22 AM
This. As long as it's a tight fit you shouldn't have any problems.
Old Dec 19, 2010 | 07:59 AM
slfalco's Avatar
On my 99, the center pipe had studs welded on to the flange where it meets the rear muffler pipe, which of course snapped off when trying to remove the nuts.. had to grind the broken studs flush with the flange, then drill holes and use bolts/nuts to fit the hole I drilled...
Old Dec 19, 2010 | 10:39 AM
KidA157's Avatar
Thanks guys; that's what I ended up doing. Muffler is all set now.
Old Dec 19, 2010 | 10:47 AM
styliztik's Avatar
14mm.
Old Dec 19, 2010 | 02:59 PM
CMax03's Avatar
I used some 3/8"-24 SS hardware from "Ace Hardware", ss bolts, nuts, lockwashers and flat washers over 7 yrs ago and they're still down there doing their job
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
dcam0326
Sep 18, 2015 04:52 PM
Johnny9595
Sep 16, 2015 07:20 PM
jcvgn
Sep 13, 2015 11:42 AM
