Crank Pulley Check
Old Dec 22, 2010 | 09:11 AM
ajcool2's Avatar
Crank Pulley Check
Hello fellow 4th genners. Just wanted to let everyone know that I've been seeing alot of stock crank pulleys going bad all of a sudden in 4th gens and some 2000 maxes. In the last 6 months I've sent out maybe 6 replacement crank pulley and my GF's broke last week. Also my boy with a 5th gen crank pulley broke on him while driving down the highway one day last month. So everyone still running their stock crank pulley might want to check thier rubber seals for cracks and anything that looks abnormal. I'll have a pic of my GF's pulley that broke up here later today. Her car only had 176k on it.
Old Dec 22, 2010 | 10:10 AM
On my old 4th gen I had 232K miles on the original crank pulley with no problems.
Old Dec 22, 2010 | 11:18 AM
cashoit's Avatar
good looks on the headsup AJ
Old Dec 22, 2010 | 11:41 AM
ajcool2's Avatar
Yeah my car is at 202K and its fine. I just see this happening more and more all of a sudden so I figured I'd let everybody know.
Old Dec 22, 2010 | 02:07 PM
It's pretty random for crank pulleys, especially stock ones to go. I wonder if there's a reason to it or if it's just from wear and tear. If it's from wear and tear yours should be gone lol.
Old Dec 22, 2010 | 08:03 PM
99BlackMaxMS's Avatar
I replaced mine this summer for the same exact reason. One day it randomly started chirping/making noise and I was actually able to see it wobbling back and forth, causing the belt to make a little bit of noise.
Around 158K on mine when the rubber seals went, however, they had seen 11 New England winters.
Old Dec 23, 2010 | 02:58 AM
tsheffler's Avatar
im on stock pulley at 239000 and it wobbles...its wobbles for the last ...well since i got the car at 194000 lol....it probably goes 2-3mm each way every rotation:/....at idle it looks like its a fan haha....but...no noise, nothin....but ima prob get a new one soon...just for shizz and giggles
Old Dec 23, 2010 | 03:50 AM
Trini Boom's Avatar
I amon 310K with stock crank pulley. I think this problem is happening if there were oil leaks above the crank pulley (meaning timing cover or PS pump) and it went on the pulley and the hot oil weakened the rubber. I have no wobbling whatsoever and also my only oil leak is from upper oil pan seals.
Old Dec 23, 2010 | 04:51 AM
cashoit's Avatar
damn trini 310k??? that maxi is a legend lol
Old Jul 8, 2011 | 05:39 AM
plugeye's Avatar
had 2 fail the same way:
the outer pulley-to-rubber bond failed. inner pulley still bonded to rubber
Old Jul 8, 2011 | 09:04 AM
ajcool2's Avatar
How many miles were on the pulley before it went?
Old Jul 9, 2011 | 05:29 AM
plugeye's Avatar
i have no idea. 1st one could be the original, went at over 200k.
the 2nd one was used
Old Jul 9, 2011 | 06:17 AM
Dhione's Avatar
mine is starting to go. you can see it start to wobble a little. time for upgrade
Old Jul 9, 2011 | 07:47 AM
hornepirate's Avatar
I believe mines starting to go too....
We shoukd set up a gd with unorthodox for crank pulleys
Old Jul 12, 2011 | 02:22 PM
ajcool2's Avatar
Bump! Check your crank pulleys before its to late!
Old Jul 12, 2011 | 04:50 PM
Trini Boom's Avatar
AJ from what I have seen thus far on this issue is that it is caused by excessive oil on the puller from leaking seals. Did any of yours happen to have oil on it when it separated? I am still on my original at 314K and it is now accumulating oil from the PS pump coming down the belt.
Old Jul 12, 2011 | 06:36 PM
plugeye's Avatar
both were dry
Old Jun 20, 2015 | 09:42 AM
max ride 41's Avatar
bumping old azz thread, 272,000 on original pulley wobbling pretty good. got a new dorman and oe belts and seal, fixing monday!! hate not being able to drive maxy around.
mvm062
Nov 30, 2020 09:00 AM
02PearlSE
Feb 1, 2016 12:37 AM
gustavison
Oct 4, 2015 06:50 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
conansriver
Sep 11, 2015 10:26 AM
