fog light install instructions 97-99
Old Jan 3, 2011 | 09:34 AM
Br0nz's Avatar
Thought this might be helpful.
Old Jan 3, 2011 | 09:57 AM
QT1 5MT AE's Avatar
Gram Lights addict
nice post
Old Jan 3, 2011 | 11:27 AM
Jayson89NYC's Avatar
nice i like this post br0nz
Old Jan 3, 2011 | 12:00 PM
maximus nismo's Avatar
Once again, thanks for posting it.
This should be made a sticky.
Old Jan 3, 2011 | 02:33 PM
luke95gxe's Avatar
^ + 1
Old Jan 3, 2011 | 03:04 PM
Leo_Koneval's Avatar
LOL I just bought a set of fogs and I was scratching my head a minute ago about the install. And I checked here and what-cha-know!
Thank you!
You must have read my mind all the way in Connecticut!
Old Jan 3, 2011 | 05:17 PM
Good find!
Old Jul 9, 2011 | 11:57 AM
tigersharkdude's Avatar
sorry for the old thread bump,
br0nz this saved me like 2 hours. I really didnt feel like taking my front bumper off again
Old Jul 11, 2011 | 06:31 PM
Chris97maxima's Avatar
Awesome post, thanks for the good info.
Old Aug 23, 2011 | 08:04 AM
~V~max's Avatar
AWOUSOME POST!!! will come in handy thanks
Old Aug 23, 2011 | 11:47 AM
hitm4n666's Avatar
hmmm it say you need a drill for wat???
Old Aug 23, 2011 | 12:35 PM
Haishun Boi Max's Avatar
Great post........
Old Aug 23, 2011 | 10:23 PM
inyoface's Avatar
thanks for the post.needed the bolt positions
Old Aug 24, 2011 | 09:16 PM
hitm4n666's Avatar
hmmmm i just swapped my front of my 95 to a 97 front. when i was in the middle of the swap i didnt not notice at all on the bumpers support were the three bolts for the mounting brackets.....
Old Aug 24, 2011 | 09:39 PM
good write up
Old Aug 26, 2011 | 08:38 AM
hitm4n666's Avatar
edit had a look again and found
Old Aug 26, 2011 | 06:08 PM
Alienwarek's Avatar
Awesome post, was just looking around for something like this
Old Jan 4, 2012 | 08:48 AM
Maxieggy's Avatar
Nice post im going to try it this weekend
Old Jan 4, 2012 | 10:06 AM
Amerikaner83's Avatar
subscribed for this one! nice.....
Old Jan 4, 2012 | 10:14 AM
isandres8884's Avatar
nice i need to find some fogs 4 my 97 max
Old Jan 4, 2012 | 05:20 PM
luke95gxe's Avatar
btw this is the same for the 95-96 just more to cut out the bumper and and u need 95-96 fogs and brackets i have a write up link below
http://forums.maxima.org/4th-generat...e-up-pics.html
Old Jan 22, 2012 | 11:35 PM
CMax03's Avatar
Most Maxima's are wired from the factory as far as the chassis harness is concerned...It may need the fuses, relay, stalk, and fog lamps too make work! Or you can wire in a aftermarket light if you know your wiring.....
Old Oct 9, 2012 | 04:53 AM
Da4gotten's Avatar
Where would I find the relay, stalk, fuses? Do most nissan certified store carry it? Or do I have to search on ebay?
Old Oct 9, 2012 | 09:51 AM
GGENIUS's Avatar
i dont think you can get them factory anymore. atleast not the stalk. i wouldjust scour junkyards till you find it all on one car.
GGENIUS's Avatar
dayumn son why would you go and do that for fogs?
Old Oct 10, 2012 | 01:02 PM
Da4gotten's Avatar
That seems like a lot of hard work for a simple install... Don't most 99' maximas come with the wiring and hardware? Im not sure.
Old Oct 10, 2012 | 05:50 PM
GGENIUS's Avatar
what is a lot of work? removing the stuff from a car at a junkyard? it takes about 5 minutes to remove the stalk. another 5 or so to remove the foglights. then about 10 minutes to remove the brackets as long as the bolts arent all seized. these are over estimations too.
your car comes will all the wiring in the right place. but thats it unless your car came with them.
Old Oct 10, 2012 | 05:51 PM
I have a complete set for the 95-96 for sale. [lights, brackets, stalk, fuse]
The wiring and the mounting holes are in all the cars already. You may need to cut the fog covers off your bumper though.
Old Oct 10, 2012 | 08:26 PM
Da4gotten's Avatar
I already have the fog lights, I'm just saying that by reading these instructions I see that I need a relay, stalk, fuse, which apparently are hard to find.
Finding a Maxima in a junkyard in my town is hard to find. Although many 99' Maximas I've seen people driving, look like they belong in a junkyard...
Old Oct 11, 2012 | 01:32 AM
submaxzero's Avatar
Yes indeed Luv aftermarket Fog light hookup running it rt off the stock wireing. I need to show u pics
Old Feb 15, 2013 | 10:21 AM
Fakie J Farkerton's Avatar
Bumping because I need this today.
Old Mar 14, 2016 | 06:58 AM
lnesomdove's Avatar
97 Fog Light Install
I have a 95 SE with factory installed fog lights, also own a 97 GLE without them Was at the pullapart getting parts for the 95 when the wife suggested putting fog lights on the 97.
I had previously read this thread and figured everything was there, all the wiring would be present, all I would need is the lights, the brackets, the relays/fuses and the turn signal stalk, no problem right?
So I look behind the bumper, wiring is there, good deal! Located brackets and lights from a 96 I believe, all I needed was the turn signal stalk.
I pulled one from a 96, got it home and the first issue was the plugs currently in the turn signal don't match up to the one from the 96. Is it safe to assume then that only 97 - 99 turn signal stalks are the only ones that will work? Or in other words, 95 and 96 will not work?
Then I also noticed that the 96 had the extra wire and connector to plug into the wiring that is supposed to be taped to the steering column. So I search and search and never find this plug on the 97.
So back to the pullapart and I do find a 97 without fog lamps for comparison. It is pre-wired for the lights at the bumper but on the steering column there isn't a plug for the turn stalk connector. According to the instructions there should be right?
So there is a Niles part number stamped on the 96 turn stalk with fog light switch, NILES 14509. The 95 has one of NILES 14511 (but even 95's on the pullapart had the 14509). Courtesy Nissan list the part number as the same as 25540-0L700 listing it with and without fog lights. That connector has to be there right?
Anyway, if only a 97 and up will work, I've got to go to another pullpart since the one I went to didn't have any 97's and up with factory installed fog lights.
So in summary:
1. Only 97 and above turn stalks yes or no?
2. There IS a connector for the separate lead for the fog lamps on the turn stalk right?
Thanks!
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
