rear speaker wiring
Old Jan 3, 2011 | 06:54 PM
shift_5's Avatar
rear speaker wiring
96 w/ bose originally. Need to know about the four wire plug for the stock rear speakers. Which wires are for the signal? Checked FSM, but it is hard to tell what is what in their diagram.
Old Jan 3, 2011 | 07:58 PM
xtremepb0's Avatar
Rear or deck?
Old Jan 3, 2011 | 08:40 PM
Maxima_Joe's Avatar
4th Gen Parts King
The larger gauge wires are the power wires (black wire and red wire). So that leaves the smaller gauge wires as the signal ones.
Old Jan 4, 2011 | 07:20 AM
shift_5's Avatar
at the rear speakers there is a four wire plug, they are all the same color wire on both sides, driver side has all larger wires and the passenger side are all thinner wires.
Are the signal wires all on one side?
Old Jan 4, 2011 | 09:25 AM
Maxima_Joe's Avatar
4th Gen Parts King
No each speak has power (red wire) ground (black wire). These are thicker wires. Then - signal wire and + signal wire. I'm at work so I do not know what color these are.
Old Jan 4, 2011 | 09:52 AM
shift_5's Avatar
ok, all the wires are the same color. check when you get a chance, that would be awesome. Thanks
Old Jan 4, 2011 | 10:45 AM
urmab's Avatar
Wait you dont have a red and black color wires, also I would check the gauge of the wires the thicker once are typically power skinnier are signal, also what color are they ?
Old Jan 4, 2011 | 11:41 AM
Maxima_Joe's Avatar
4th Gen Parts King
Can you take a pic of your plug and wiring?
Old Jan 4, 2011 | 01:21 PM
DennisMik's Avatar
I'm wondering if someone re-wired the speakers.
I looked in the FSM and the wires are not all the same. Both plugs do have a red and black wire for power (red = 12 volts pin 3 and black = ground pin 1) but the signal wires are different for each side.
For the left rear speaker, the wires are red and green (pins 2 and 4 respectively) and the right side uses pink and blue (again pins 2 and 4 respectively).
I hope you can post a photo.
Old Jan 5, 2011 | 04:23 AM
shift_5's Avatar
I will snap a quick picture today. Unless I'm an idiot and these are not the speaker plugs. They are the only two plugs dangling right near each of the rear speakers.
Old Jan 6, 2011 | 07:13 AM
shift_5's Avatar
I put up pictures in my album, sorry I don't have anywhere to post it right now. But there is a picture of the driver and passenger side. Thanks for the help guys.
Old Jan 6, 2011 | 09:12 AM
Maxima_Joe's Avatar
4th Gen Parts King
It's hard to tell since I'm on my phone but it looks like someone extended the wires. Is that electrical tape about 6" from the plug?
Old Jan 6, 2011 | 12:28 PM
urmab's Avatar
It seems like someone already spiced those wires can u take a picture after the electrical tape or all the wires there are black
But anyways here
Here is your connector
According to fsm
Pin 1: Ground
Pin 2: Signal +
Pin 3: Power
Pin 4: Signal -
Old Jan 6, 2011 | 02:50 PM
shift_5's Avatar
Excellent, I'm going to give it a shot tomorrow. Thanks man! I think he may have been tapping off of that power to turn a amp on back there.
Matt93SE
May 24, 2019 02:58 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
jskirwin
Jun 8, 2016 08:49 AM
melteye
May 16, 2016 12:02 AM
Huttig2009
Sep 25, 2015 03:31 PM
