2000 rpm limit on 95 Se
Old Jan 27, 2011 | 08:52 AM
Daily Interlude's Avatar
I see the MAF and CTS could cause this. Is there any other sensors I need to check that cause the engine to go into fail safe mode where it only revs to 2000 rpms?
Thanks!
Old Jan 27, 2011 | 09:00 AM
tigersharkdude's Avatar
MAF
Old Jan 27, 2011 | 09:06 AM
The only ECU code I got was 11 (CPS) which didn't even turn the light on. I only found it from pulling the codes...
Old Jan 27, 2011 | 09:18 AM
Usually it wont throw a code unless you drive around for a little while with it like that. Try the CPS though, if that is the code its throwing.
Old Jan 27, 2011 | 10:20 AM
Change that CPS. If that doesn't solve it, check your MAF.
Old Jan 27, 2011 | 10:43 AM
It was the CTS...the CPS error code comes up now and again but for an unrelated reason.
I was searching and saw someone mention that their fans where on all the time in addition to the rev limit and tested their CTS and it was bad. After swapping the car didn't rev limit at 2000 rpms anymore. Mine did the exact same thing as theirs...and is now fixed after swapping the CTS just as they did.
Thanks!
Old Jan 27, 2011 | 12:21 PM
WielkiWaac's Avatar
MaximaDriver
Looks like your MAF sensor said good bye.
Old Jan 27, 2011 | 03:40 PM
FallenOne's Avatar
MAF. Clean it, Ohm It, if its toast get a new one. Meaning go to your Junkyard.
Old Jan 27, 2011 | 07:01 PM
You both did see that it's fixed, right? CTS this time...
Old Jan 27, 2011 | 11:01 PM
dame_dashvq30's Avatar
lol its funny my car did this same problem ,, but all i did was disconnect the battery over night the next day it was fine ...
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
