what is the brightest trunk light bulb one can get without mod?
There is not a true replacement bulb from anyone except Nissan. It is very similiar to the type 89 lamp, but the Nissan lamp is much brighter. The bulb uses the G6 Single Contact Bayonet (Ba15S) Base also called the minature bayonet base. About the only thing that would be brighter than the Nissan lamp would be LEDs.
But be advised that the map light lamp socket is reverse polarity so if you get a LED lamp, you will have to re-wire the socket.
if you go to racingline's page,search altima..you will see its just two LED strips connected to a very small connector tht plus into the stock socket..
sorry i don't see the connector but it doesn't matter for me. flea bay is ~2.50 for 10 194-base that fits directly into the socket. there are no other connector needed.
Look up "smd led". No mod necessary, plug and play and stick wherever you need it. I have 2 light strips in my trunk, each strip has 30 lights. It'd ridiculously bright. And took 5min to install.
Dr J
Dr J
if you google shopping for smd led strip, there's a bunch. I got mine for $1 shipped from ebay. I couldn't find any specs on my exact model, but I'd say about 3.5watts each. What makes strips effective is that you can place them anywhere, so there's less shadows.
This was taken during daylight.
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs446.ash2/71932_10150098510510744_507810743_7460314_7673123_n.jpg)
And then my friend's trunk at night
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs391.ash2/66919_10150098511045744_507810743_7460316_5172960_n.jpg)
Dr J
Dr J
Former3G
10-26-2015 11:34 PM
Dennis Twohy
10-01-2015 06:01 PM
King_Ten_Ahead
09-30-2015 04:27 PM
MikesChevelle
08-06-2015 11:36 AM
