headlamp removal (cash reward if advice works)
Old Feb 7, 2011 | 02:25 PM
Pilot8680's Avatar
I'm trying to remove the headlamp off my 4th gen Maxima. The two screws behind the lights in the engine bay is a ***** to get to. If anybody can offer some useful advice on what tools to use, I will reward them cash.
Old Feb 7, 2011 | 02:28 PM
MaximaSpd85's Avatar
3/8 drive, 3 inch extension, and a 10mm socket. theres a thick harness in the way a little tiny bit, just push it up a little.
Old Feb 7, 2011 | 02:42 PM
GGENIUS's Avatar
are you kidding me?
Old Feb 7, 2011 | 03:07 PM
99greddymax's Avatar
deep socket ftw!
Old Feb 7, 2011 | 03:11 PM
Deep socket 10mm with a 3" extension. Don't forget about the 2 two 10mm bolts once you remove the corner lights.
Old Feb 7, 2011 | 03:13 PM
tigersharkdude's Avatar
SMFH!!!!
Old Feb 7, 2011 | 03:29 PM
MaxiTan's Avatar
Oh my god I was just about to pull my hair out until I saw this thread, maybe someone can help me. I believe the previous owner had some radiator work done on my car. The tubing that brings down the radiator fluid from the radiator is COMPLETELY in the way of the two screws on for the assembly. Name:  cEX0g.jpg
Old Feb 7, 2011 | 03:45 PM
That can be moved to the side. There should be enough slack to allow you to get the socket/ratchet in there.
Old Feb 7, 2011 | 04:09 PM
MaxiTan's Avatar
The real problem is not the larger 10mm bolt, but the smaller screw that's just above it. I can't fit a crescent wrench in there let alone a socket.
Old Feb 7, 2011 | 04:17 PM
Flava_24/7's Avatar
Boosted Panda
Why in the h3ll would you try and put a crescent wrench in there??????????
A socket will work just fine, use a deep socket.
Old Feb 7, 2011 | 04:22 PM
Seriously??
Deep socket with extension will get the job done. But if youre a real pansy a swivel joint will help, but if you arent mechanically inclined enough to figure out you need an extension, Im sure you dont even know what a swivel joint is
EDIT: everything in the above pic looks stock
Old Feb 7, 2011 | 05:15 PM
beegeezy's Avatar
Ughhh...take it to the dealer and pay them $90 an hour. It's obviously impossible.
Old Feb 7, 2011 | 05:23 PM
Old Feb 7, 2011 | 06:52 PM
Pilot8680's Avatar
Wouldn't the ac line on both side of the radiator be in the way of the deep socket?
I tried but the line is directly behind the larger bolt which makes it harder to get to.
Old Feb 7, 2011 | 07:03 PM
It can be done. We've all done it, its not hard
Old Feb 7, 2011 | 07:07 PM
mista0406's Avatar
+1^^^^^^ deep socket FTW
Old Feb 7, 2011 | 10:17 PM
Decimus Meridias's Avatar
I swapped 97-99 headlights into my 96 couple months back. didn't take more than a few minutes for either of them. i do remember pushing the a/c line out of the way, but don't remember having much trouble. I probably used a small 1/4" drive ratchet and maybe a deep socket, but I don't think so. Maybe you're trying to use something too big to fit...crescent def. won't work.
Old Feb 7, 2011 | 10:34 PM
Deep socket 10mm with a 3" extension. Don't forget about the two 10mm bolts once you remove the corner lights.
You can do it!
Old Feb 8, 2011 | 05:05 AM
Haishun Boi Max's Avatar
Deep socket 10mm with 3 inch extension
Old Feb 8, 2011 | 05:26 AM
luke95gxe's Avatar
agree with all of the above i just swapped my 95-96 lights out with 97-99 lights and i dint have a problen used a 3 inch extension and deep 10mm socket
Old Feb 8, 2011 | 06:24 AM
njmaxseltd's Avatar
1/4 inch drive, swivel on the end of an extension with a 10mm socket.
It's a 10 min. job, really.
Old Feb 8, 2011 | 07:06 AM
I dont think the OP would understand how a swivel joint works, since he cant figure out he needs a deep socket and an extension
Old Feb 8, 2011 | 10:02 AM
adroitcaptor's Avatar
Do not worry about tigershark and his swivel joint (universal) put down. I am hosting a live how-to video on universal use with ratchet drives. This will help you get that headlight out. Pm me for sign-up. $50 charge gl
Old Feb 8, 2011 | 10:10 AM
cardana24's Avatar
Blown
IN FOR THE CASH REWARD!!! put a wrench on it
Old Feb 8, 2011 | 04:56 PM
beegeezy's Avatar
One word: Sawzall
Old Feb 8, 2011 | 05:46 PM
GGENIUS's Avatar
just grab the front of it and rip it out.
Old Feb 8, 2011 | 06:02 PM
THIS
Old Feb 8, 2011 | 07:36 PM
RA121625's Avatar
Its obviously impossible.
If you're offering a cash reward then why not just pay a mechanic for 10 min of labor to do it for you?
Old Feb 8, 2011 | 07:43 PM
NOOB WIN!!
Old Feb 8, 2011 | 10:38 PM
If you're in the NY/NJ area I'll do the headlight swap for you.
Old Feb 11, 2011 | 07:46 PM
a32 infiniti's Avatar
hey ime a noob and cracked one of my corner lights when i took out the reflector trying to white it out .....will the maxx's corner lense fit my I30?...if not do they sell solid orange jdm style lenses
Old Feb 11, 2011 | 08:09 PM
IIRC there is a set of I30 corners in the 4th gen classifieds
Old Feb 12, 2011 | 04:54 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
smash with hammer till it comes out. ill take my pay now....lol
Old Feb 12, 2011 | 10:43 AM
I'll be removing them for him lol.
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
raffivegas
Aug 23, 2015 09:54 PM
Superbform
Aug 11, 2015 08:10 PM
kenc15
Aug 5, 2015 08:29 AM
