water in trunk
Old Feb 17, 2011 | 06:38 PM
luke95gxe's Avatar
water in trunk
hey guys i have water in my trunk where the spare sits the carpet is not wet and the rubber plug under the spare is intact any input?? i saw it bout to weeks ago dryed it out and yesterday there was more? it did snow and the car sat for a few days
Old Feb 17, 2011 | 06:53 PM
A.Cordeiro's Avatar
rubber seal around the trunk is probably ripped somewhere...open the trunk look for rips or tears in the seal or see of the trunk is out of line a little
Old Feb 17, 2011 | 07:01 PM
luke95gxe's Avatar
trunk is off a lil previous owner (friend of the family for years) had t ton of stuff in and tried to keep slaming it shut whats the best way to make it right again and there is no tension in the trunk when opening and closing just falls shut hard
Old Feb 17, 2011 | 07:07 PM
A.Cordeiro's Avatar
that little offset is probably what is causing the issue..all that snow sitting on top melted a little and slowly filled up the spare tire area.
Old Feb 17, 2011 | 07:22 PM
Trini Boom's Avatar
My man, you are going to be on a wild goose chase with this leak. I have been trying from since the past summer to find it and it is very difficult. I can give you some starting points..
One of my first leaks was coming from the latch in which part of the weatherstrip was not pushed in fully. Fixed
Second leak was from the top right side where the runoff for the trunk is. There is a seem where the metal joins. On the inside of the trunk, it was dripping from there after going to observe after a heavy rainstorm. Fixed with some silicone on the inside.
To this day, still leaks and I was not going to troubleshoot through the winter so I took out both plugs from beneath the spare and left it at that for now. Hope this helps.
Old Feb 17, 2011 | 08:16 PM
luke95gxe's Avatar
figured it wasnt going to be easy since the carpet doesnt get wet but ill deff look into it some more if i find something amazing lol ill let u know
Old Feb 17, 2011 | 09:13 PM
DennisMik's Avatar
If the water leaks in around a tail light, it can run along the inside edge of the trunk and not get the carpet wet. Take out the carpet and maybe you can see water tracks.
If you have to, take out all the inside trim panels and carpet. Get in the trunk with a light and have someone hose down the car from all directions.
Old Feb 17, 2011 | 09:20 PM
luke95gxe's Avatar
this sounds like a good idea
Old Feb 18, 2011 | 05:50 AM
txsilverado1's Avatar
I have actually cleaned the sealing area real good "trunk lid and seal" and put a light coat of vaseline on the rubber seal, then lightly close the trunk lid. Any where there is not vaseline transfer to the trunk lid is a suspect area.
Old Feb 18, 2011 | 06:18 AM
kel456's Avatar
how about taking a hose and run water around the trunk area. look inside from the rear bench with a bright light.
Old Feb 18, 2011 | 01:54 PM
Trini Boom's Avatar
If it was this easy, we would have fixed this issue by just going through a car wash and finding it. For some odd reason, only natural rain is when you see the leaks.
Old Feb 19, 2011 | 12:01 AM
Dooly's Avatar
Its just an A32 thing. Maybe even all maxima's in general. Mine doesn't count because my lid is jacked up anyway, but my friends trunk leaks on his I30, and all the 4th gen maxima's and I30's in the junkyards have moldy carpets and stuff from leaky trunks.
Old Feb 19, 2011 | 02:37 AM
blue_magicSE's Avatar
This is exactly what I had to do when I change my taillights over to 01Se tails. Found a lake of water sitting where my spare tire went.
I used sealant all around the taillights where it met with the body. Ran water after it the sealant was dry ano more leaks.
You can try this. See if it work
Old Feb 19, 2011 | 07:14 AM
tigersharkdude's Avatar
did you just change the wording, but copy what dude said to try and make it look like your own idea?
Old Feb 19, 2011 | 08:01 AM
metallic97gxe's Avatar
Master Will
put a water hose on your trunk turn it on slow and watch where the water enters then try to seal it up there
Old Feb 21, 2011 | 03:26 PM
luke95gxe's Avatar
well we had a good rain today i went out side and opened the trunk and water was coming in from the driver side tail light on the deck lid i wonder if its from the light or the spoiler gettin dark out side now will have to take a deeper look tomorrow
Old Feb 21, 2011 | 03:44 PM
GGENIUS's Avatar
hey i think you shouldnt listen to these mother****ers sayin to use a hose. get in the trunk and drive it into the ocean
Old Feb 21, 2011 | 03:52 PM
luke95gxe's Avatar
problem has been found havent had time to get in the trunk and have someone spray it with a hose i just moved
dont understand the smart a** comment
Old Feb 22, 2011 | 04:40 AM
Trini Boom's Avatar
Hmm, I did this also but mine is permanent because I used silicone to reseal both lights and I still have a leak. Hope that's the end of it for yours.
Old Feb 22, 2011 | 07:28 AM
njmaxseltd's Avatar
Most trunk leaks come from the tail lights not the upper lid seal. There's a channel deep enough that water never contacts the lid seal. That channel around the trunk drains right over the tail lights. There's your leak, and it's very common not only in Maxima's but on lots of vehicles.
REDinLV
Aug 15, 2024 12:30 AM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
