talk about luck......
Old Feb 19, 2011 | 11:20 PM
max ride 41's Avatar
i just had a check engine light pop on last night, and guess what i did last monday, inspection!!! so, if i had waited like i was going to to get the inspection done it would'nt have passed. yeah, i know you can reset the codes and wipe it away. here's the good part, the tank was a quarter full so i put some bg gas treatment in and when i came back out of the food store the stutter was gone, ( im guessin an injector ) and she's running smooth as silk now. i figure the injector clogged or something and it stopped working properly. lucky me!!!!! fingers crossed
Old Feb 20, 2011 | 04:07 AM
Trini Boom's Avatar
Yeah its going to come back at some point. Mine just did this while on the highway cruising and the CEL came on flashing for cylinder 4 misfiring and O2 sensor. Drove around local streets and it took itself off and codes disappeared. Next 2 days, started her up from cold and was rumbling like hell. I just swapped out the injector and all is well now...good thing it wasn't one of the ones under the manifold as I just changed all the gaskets
Old Feb 20, 2011 | 06:27 AM
i just did front and rear valve cover gaskets and thought about telling my tech to do the 2 rear injectors that i think are original, did'nt want to spend the extra cash to do as money is tight. i think its my front number 6 injector which has gone bad 2 times now in 8 months. any reason why it would go bad??? anyone??
Old Feb 20, 2011 | 06:46 AM
Trini Boom's Avatar
Two times in 8 months? Are you using OEM injectors?? Doesn't make sense to me..I am still on my originals
Old Feb 20, 2011 | 07:50 AM
no, aftermarket. one was remanned and another new. any place i can get oem new cheap?? im not doing used, had headaches with that b4 as well. oh, i have 215,00 on maxy....
Old Feb 20, 2011 | 08:30 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
believe it or not the injectors do get clogged have you seen how small the four holes are on those things ? injector cleaner is a good thing to add once in a while.
Old Feb 20, 2011 | 09:47 AM
eddie982's Avatar
Thats the brand, BG? I wanna try it too
Old Feb 20, 2011 | 12:00 PM
yep. bg from the dealer. its about 5-6 bucks and you add to an almost empty tank so it does'nt get diluted. i think they say to add to a full one but it worked better for me the other way around. i found out its cylinder 1 misfire, got it scanned today at autozone. where do i get an oem injector for a good price???
Old Feb 20, 2011 | 06:55 PM
Trini Boom's Avatar
Aww man. Not sure but don't get AZ one. It works fine but fitment is not great. Mine cracked installing into the rail.
Sorry to hear you have to go under the manifold..
Old Feb 20, 2011 | 07:48 PM
well, maybe not yet. im having advanced auto reset the ecu tomorrow and im putting premium gas in and hopefully the c/e light stays off.
foamerdave's Avatar
Harry's You Pick It (wegotused.com) In Pennsburg. Go in and grab 3 fronts off of one car and 3 fronts off another, send the set out to be professionally cleaned. For close to the the cost of one new oem you can have a set of 6 that have been cleaned,tested, and new o rings. Best bang for the buck that I can think of
Old Feb 20, 2011 | 09:39 PM
beegeezy's Avatar
Fuel injector cleaner is such a ripoff. Gasoline will eat away any deposit that a cleaner will, especially at high pressure/volume. Once injectors get clogged they need to be cleaned professionally or replaced.
Old Feb 21, 2011 | 07:01 AM
i had the injectors cleaned a few months back. i think the fukoil gas is making maxy run like $hit and clogging them.
Old Feb 21, 2011 | 07:23 AM
ampire's Avatar
Don't remember seeing any 4th gens at Harrys but I havent been out that way in 3 years.
How many Maximas do they now, is it more common?
Strangely enough, they had like 4 Taurus SHOs, which my buddy and I all but gutted lol.
Old Feb 21, 2011 | 02:48 PM
and viola!!! i go to leave for work this morning, start up maxy and the light is gone!!!! self fixing maxima!!! yesssssssss!!!!!!! i did add a little bg, but i hoped it was just clogged and it seems to have worked!!!
Old Feb 22, 2011 | 04:09 AM
foamerdave's Avatar
As of right now there has to be 7 or more 4gens
Old Feb 22, 2011 | 11:01 AM
FallenOne's Avatar
I have a set of Injectos with fuel rail for sale buddy,some repeat buisness for ya ?
Old Feb 22, 2011 | 11:15 AM
cashoit's Avatar
Have u seen my sig. Chevron Techron all the wayyyyy
lukoil FTL. I used that sh*t cuz the guy at advance recommended it. My car ran like crap until the tank was empty.
xUNIxPanther
Dec 6, 2020 09:08 PM
James92SE
Oct 8, 2015 04:57 PM
litch
Sep 5, 2015 11:29 AM
crazyespn
Sep 3, 2015 01:30 PM
