HELP! clutch problem!!
Old Feb 26, 2011 | 09:39 AM
blac99max's Avatar
ok so i bought a competition clutch and pressure plate not too long ago and had someone put it in and they just got back to me saying that it was installed but it will not disengage. idk what the problem could be...maybe no pressure in the lines? any ideas on where to look first?
Old Feb 26, 2011 | 10:07 AM
Jdmfosho's Avatar
did you bleed the clutch lines?
Old Feb 26, 2011 | 10:11 AM
blac99max's Avatar
the guy who did it said he didn't bleed them because he only removed the slave cylinder off to the side. but i don't see why you wouldnt bleed it.? its like doing your breaks and not bleeding those lines. he said he is going to bleed the line today so we'll see what happens. having an aftermarket more aggressive clutch would be the problem would it? also i didn't have the flywheel changed...just had it cut
Old Feb 26, 2011 | 10:18 AM
luke95gxe's Avatar
he needs to bleed both lines the one to the slave and the one thats on the passenger side strut tower and what do you mean by you cut the flywheel ? do u mean resurfaced?
Old Feb 26, 2011 | 10:26 AM
blac99max's Avatar
yea..resurfaced. and i just got off the phone with him again and he said that tomorrow he will power bleed the system and see if that is the problem. he was saying to me that the pressure plate seemed as if it wasn't working properly maybe faulty? also is it possible that the slave cylinder isn't creating enough pressure?
Old Feb 26, 2011 | 10:37 AM
luke95gxe's Avatar
the slave could be toast or the master could be toast or u could have a leak in the line but i really think it could be installer error is this a shop or a friend? i also think you should be there to see what is going on to give us a better explantion of whats going on and whats been done there also could be a issue with the shift fork cold be bent or not istalled right when the tob was put on
Old Feb 26, 2011 | 11:00 AM
blac99max's Avatar
he is a friend but was also a tech at ford for 19yrs. and believe me id love to be there but the car is an hour n a half away so its a little hard. but i doubt the fork is bent. car ran perfect before all of this...minus the slipping of the old clutch
Old Feb 26, 2011 | 12:45 PM
asand1's Avatar
Disc could be backwards, pushing the hub and springs into the flywheel bolts. If he didn't open the clutch lines, they should not need bleeding and wont cause your problem. Could also be improperly installed throw out bearing or improperly surfaced flywheel.
Old Feb 26, 2011 | 09:50 PM
adroitcaptor's Avatar
agreed... It is not a requirement.
That said, I am not sure I would put that amount of time in and NOT bleed the lines, MS, and SL. You do not go through many clutches over the life of a car. It is best, IMO, to flush, replace, and bleed your clutch system.
It is really hard to understand what actually happened. From what I read I would be more worried that he did not know what he was doing or that he did an improper job. (Years on the job /= knowing correct procedure.) If he did install it wrong, I would be very passive about it. People will lie to avoid a supposed reaction.
I think you need to start over and TS this as a new problem. Let us know what you find with each component and step. That way we can give you accurate advice.
Old Feb 27, 2011 | 10:19 AM
blac99max's Avatar
just ended phone call number 3. he said he bled the whole system and still nothing. he also moved the fork manually and still nothing. he says he still thinks its a bad pressure plate. i will be calling the company this week to see what they have to say and he's taking the tranny apart again this week. so well see what happens now. thanks for the advice everyone
Old Feb 27, 2011 | 10:54 AM
luke95gxe's Avatar
good luck and let us know the outcome
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
