HOW-TO: Clean, remove the haze, de-yellow your headlights
Old Feb 28, 2011 | 10:18 PM
maximus nismo's Avatar
I'm going to be doing a HID Projector retrofit soon so I decided to clean the headlights on my wife's maxima.
The following is a write up with pictures of the products and procedure I used. Hopefully this can help someone else.
Sandpaper for Wet sanding : 1000, 1500 and 2000 grit.
Painters tape
Nitrile golves to protect your hand
Oderless Mineral Spirits Model # QKSP94005 / Store SKU # 200658 Home Depot Link
Minwax Helmsman UV Sealer Model # 63210 / Store SKU # 422541 Home Depot Link
An old drywall sander I found
A shop towel
Container to mix the UV sealer
measuring instrument for UV sealer mix
Not pictured - spray bottle for wet sanding.
Before Pictures
Wash the lights and tape off the areas you do not want the sandpaper to scratch.
After sanding with the 1000 grit, I got this:
Move on to the 1500 grit and got this result
2000 girt gets.....
Opps, gotta find those pictures.
Next step is to rinse and dry the lights off and prepare your UV treatment.
Since the sanding is removing the old protection from the elements and UV rays, you are now going to replace it. I found out about this method from another forum which pointed to yet another forum. The person who did this had some pictures a year adn a half later and the lights still looked the same.
Here we go.
Mix 1 part mineral spirits to 1 part Minwax helmsman sealer. I used a shop towel to gently "paint" the lens. Be careful not to let it run. If it does, clean it off with some of the mineral spirits and start again. When I do this to the 240sx, I'll use a 1" foam brush to apply the sealer.
UV sealer stage after 1 application.
Took the car for a drive at night and there was a lot more light on the road than before.
I wonder what this method will do for the 240SX?
Old Feb 28, 2011 | 10:19 PM
More Cleaning
I purchased a second set of lights to do the retro and went through this same process again, but this time at night, in the house with the wife and kids sleeping upstairs; so I had to had sand everything.
I added one more step to the process. I had some Novus 123 laying around so I used the Novus 2 and Novus 1 after the wet sanding and before the UV sealer application.
The headlights and been pulled apart by the previous owner and an Anniversary Edition mod was done to the reflector shield. This is how they were when I got them and after I removed the lens.
All pictures were taken with a Nikon D3100 and were only converted to jpeg to upload. They were not tweaked in any way.
Novus Product
Final Results.
Since I sanded and polished it with a bum shoulder, I was not able to get all the fine marks out. This is where a buffer with a 4" pad would come in really handy.
You can see the fine marks here.
Needles to say, I am really pleased with the outcome.
Now go forth and clean!
Old Feb 28, 2011 | 11:25 PM
beegeezy's Avatar
Good job!
If you don't want to buy all that stuff 3M makes a kit that they sell at Autozone for around 15 bucks. Does the exact same thing, several stages of sanding and polishing too. I used it on mine and they look like yours now. Oh, and you use a corded or cordless drill for the sanding/polishing instead of that big sander you used.
Old Feb 28, 2011 | 11:29 PM
beegeezy's Avatar
http://www.youtube.com/watch?v=_t1RBw0IGXA
The video sounds like the same people who do driver's safety videos for driver's ed.
Old Mar 1, 2011 | 08:25 AM
Nice work! Both sets look brand new.
Old Mar 1, 2011 | 08:30 AM
cashoit's Avatar
Yo i need to do this!!
Autozone makes a kit? And sanding wont hurt?? U guys sure?
Old Mar 1, 2011 | 10:35 AM
sbushnak's Avatar
I sanded my I30 headlights with the same grit paper as OP, and it did not damage the headlights. The output got better.
Old Mar 1, 2011 | 10:38 AM
cashoit's Avatar
YEah ima get this stuff from AZ soon as i get off work and give it a shot.
Old Mar 1, 2011 | 02:01 PM
luke95gxe's Avatar
yeah the have a kit that goes on ur drill works good i used em om mine
Old Mar 1, 2011 | 02:58 PM
Dougy Trah's Avatar
(First post ever )
I did mine when I first got my max and it turned out great
Old Mar 1, 2011 | 03:00 PM
xtremepb0's Avatar
That came out wicked nice! I wonder how this would compare to the mothers headlight cleaner. Havent used either of these but my max is dying to get her head lights cleaned.
Old Mar 1, 2011 | 03:34 PM
98MaximaDriver's Avatar
Wow, Good job!! Mine arent to bad so ill wait but ... My first maxima had it bad .. i wish i knew you about sanding it and the sealer..!!
Old Mar 1, 2011 | 05:13 PM
Swazey's Avatar
wow talk about before and after pics! my headlghts arent all that hazy/yellow but im sure it will help regardless.
Well done!
Old Mar 1, 2011 | 05:25 PM
mayur914's Avatar
nice pics man. even when i did mine they looked awesome after. i like those headlights instead of the ones with the alignment lines.
Old Mar 1, 2011 | 05:58 PM
kasemodz's Avatar
I start with wet (has to be 3m wet n dry) sand paper too , but I start with 400 grit --> 800 grit --> 1000 grit --> 2000 grit; switching direction perpendicularly after each grit change (i.e. 400 grit -- left to right, 800 grit -- top to bottom, etc.). I mix water with a half a teaspoon of dish washing liquid. I use that to keep the headlights wet at all times. Next, after completing the 2000 grit process, I follow it with some mothers mag & polish with some elbow grease and a microfiber cloth. Then I follow it with meguiars plastx and elbow grease, then meguiars cleaner wax, followed finally by meguiars nxt 2.0 wax. The nxt 2.0 does a nice job of polishing and has uv protection as well. Either way, same results.
Old Mar 2, 2011 | 06:40 AM
True, true. A bit of soap keeps it slippery for the wet sanding.
I've done this before on my 240SX, about 3 years ago, but I used 400, 600, then 800 grit. I didn't know better then. My worst mistake was I did not use any UV sealer. The way they look now is what happens when you do not replace the UV protection. Any sanding/ polishing method will remove the haze/yellow and get your lights clear, but you have to seal/protect them somehow to maintain the clarity.
I'll have to revisit this in a year and post some follow up pictures.
Old Mar 2, 2011 | 08:38 AM
Trini Boom's Avatar
This needs to be in the stickys...well done job!
Old Mar 2, 2011 | 08:42 AM
tigersharkdude's Avatar
There are a few methods in the stickies in the detailing section
Old Mar 2, 2011 | 03:13 PM
GGENIUS's Avatar
i did this but a lot simpler. i just wetsanded with 1000 and then cleared them. bam. look just like the ones in the pictures.
Old Mar 2, 2011 | 10:37 PM
Reality sucks's Avatar
Tha 3M Headlight resto kit works wonders on plastic lights. im going to do a sticky on it my self. Just to bump a great product...
Old Mar 3, 2011 | 03:38 PM
mayur914's Avatar
Do it!! I did that on mine and can see through the lens whoo. still clean and smooth 5 months later.
Old Mar 3, 2011 | 08:01 PM
mateusz1945's Avatar
Hey OP you sure moved headlight restoration to next level.but i got some crazy idea...
have you ever use polishing paste? in case i have some pastes up to 15000 grid that my brother used to polish his sword to mirror finish. wondering how would that finish look like on headlights...
Old Mar 7, 2011 | 09:06 AM
If I had a Random Orbital Polisher, I'd use it withe the 15000 grit paste you have to get a better and faster finished product.
I'd still use the UV coating thought to keep it looking nice in the long run.
Old Mar 7, 2011 | 10:16 AM
andersonrandy5's Avatar
Damn that look so much better!!!! I need that bad on mine. I saw a kit in a flat silver package at walmart has anyone used this one and what were the results?
Old Mar 10, 2011 | 09:32 PM
Akiyukio's Avatar
Bumping this thread, I am looking to restore my headlights in preparation for my new FX-R projectors.
Does anyone have any experience with the:
Turtle Wax kit? Link
Sylvania Kit? Link
I am looking at these mainly because I don't have a cord/cordless drill that I can attach the sanders/polishers to. Hand sanding all the way..
Old Mar 11, 2011 | 12:24 AM
mayur914's Avatar
Sylvania Kit? Link
I have heard the turtle wax one work pretty well i have heard does wonder. I actually used rain x before i had used the 3m restoration kit.
Old Mar 11, 2011 | 09:35 AM
Akiyukio's Avatar
Thanks, I guess for around eight dollars, I can afford to try it out.
Worse comes to worse, I'll swap my old lenses from before my retrofit over. They're slightly better, but not by much.
Old Mar 11, 2011 | 11:13 AM
Product_Of_Korea's Avatar
Ive had good sucess with the 3m headlight restore
Old Jan 7, 2012 | 07:12 PM
02SEinStL's Avatar
I've had great results on many different vehicles just using Meguiars Cleaner Wax - the "cleaner" part is a very mild abrasive that also works wonders on scuffs and paint rubs from door dings. It can take some elbow grease but it's well worth it. It leaves a good protective wax coating as well. When I got my Maxima the headlights were ROUGH but after hitting them hard with the Meguiars they are almost totally clear now.
I may try the wetsanding and sealing deal though - the UV protection seems like a smart idea.
Vistance
Sep 17, 2015 05:17 AM
seesole
Sep 14, 2015 12:38 PM
Hdnseek
Sep 9, 2015 05:55 AM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
