Clutch Woes
Clutch Woes
Hey guys! Long time, no see. I'm having an issue with my clutch and was unable to find another thread where someone's exact symptoms matched mine. For starters, before yesterday, the car ran and drove perfectly. Keep that in mind. This is totally just a "car sat overnight and developed problems" issue, and I did not do anything out of the ordinary in the days leading up to the issue. So here's the rundown:
-Clutch pedal has to be pressed practically all the way to the floor, so I have ~0.25" of pedal travel at the bottom where the clutch is actually doing anything. Previous to this, the clutch engaged almost at the top of the travel.
-Car will go into gear, but it's very difficult and more or less forced, but not quite.
-There is a distinct squeaking noise I can hear when I press/depress the clutch pedal. It is not the return spring, because that's always been squeaky on my car and I know exactly what it sounds like. This is a separate noise.
-I checked the reservoir, and it was low but not empty. I filled it up to just about the "max" line.
-I checked for puddles/drips on the pavement and on the bottom of the car and found nothing. I also looked around the master cylinder and didn't see anything leaking, but was unable to get good light to check out the slave.
Basically, the clutch barely works and the car is more or less undriveable at the moment. Any thoughts?
Yur slave prolly gone. When mine went, there was no puddle or anything under the car, jus a loss of clutch pressure.
In fact, now that i think about it, the slave had been going for some time. For example, before it went sometimes the clutch engagement point would lower while driving. Since replacing it, no issues.
I did replace master and slave. Both were like 50 bucks.
My pedal suddenly acted up when we had freezing weather. Inspected under the hood and realized the clutch cylinder had no fluid and the rubber line going to the clutch actuator had fluid on it like it had been leaking for some time. Right now I'm waiting on the ss line to show up in the mail to replace it. It is kind of a pain to drive but I've been doing the rpm shifts which help, it pretty much shifts with the pedal all the way to ground, but it take a bit of pressure to do so. What I did find out is that from a dead stop if you need to go into first or reverse it would go a lot easier if I pumped the pedal a couple times.
By the way, turns out the master cylinder was toast. I'm having my guy replace the lines and the slave cylinder while he's at it.
Mar 12, 2020 12:06 AM
carlosvq30
Sep 26, 2015 09:44 AM
