TRANSMISSION SOUND AFTER 5 SPEED REBUILD?!!!
Old Mar 15, 2011 | 05:32 PM
mpvibes's Avatar
I recently had my 5 speed tranny fully rebuilt (synchros, bearings, seals, etc.) When I first cranked it up and drove it, it made a continuous sound (not a bad sound). A friend of mine who is a mechanic said that the sound is normal for a fully rebuilt tranny and it will eventually go away. So far I put 400 miles on the rebuilt tranny and the sound is still their but, its not as loud when I first drove it. I hear it in 1st, 2nd, and 3rd. 4th and 5th I really cant hear it as much because of my loud exhaust. My question is when will this sound go away and is this normal after a rebuild?
Old Mar 15, 2011 | 07:01 PM
mpvibes's Avatar
Anyone ever had a full 5 speed rebuild?
Old Mar 15, 2011 | 08:35 PM
mpvibes's Avatar
Does the transmission have to break in?
Old Mar 15, 2011 | 09:39 PM
99greddymax's Avatar
I had a trans rebuilt, it didn't make any noise when installed.
However when my trans was going out the ips bearing made a whirring noise all the time.
Old Mar 15, 2011 | 09:48 PM
beegeezy's Avatar
Can you elaborate on the type of this sound? In my experience, when a manual transmission is making a constant sound in all gears it's do to something being too tight. Maybe the shop made some clearance level too small? Kinda a shot in the dark though...
Old Mar 15, 2011 | 10:19 PM
mpvibes's Avatar
Its more of a subtle whining noise when I drive in 1st, 2nd, and 3rd.
Old Mar 15, 2011 | 10:21 PM
mpvibes's Avatar
No whining noise? Did u also have your syncros replaced?
Old Mar 15, 2011 | 10:28 PM
mpvibes's Avatar
I was doing some research and I found this link, go to post# 135 http://forums.maxima.org/4th-generat...roblems-4.html
I know I'm not the only one who has experienced this. My transmission shifts excellent and there is no leak. I need jtzmax or dgeesman (dave) to give me some true input on this.
Old Mar 15, 2011 | 10:52 PM
beegeezy's Avatar
Mine whines in 1st, and a little in 2nd and 3rd if I'm very light on the throttle. I also have 151k on the original unopened transmission though.
Does yours whine under half+ throttle in 2nd and 3rd?
Old Mar 15, 2011 | 11:31 PM
j-dawg's Avatar
Did they rebuild your diff as well?
What fluid did they use?
Old Mar 16, 2011 | 05:22 AM
cashoit's Avatar
That was gonna be my suggestion...did they use GL-4 gear oil. I got that synthetic gear oil from Valvoline Instant oild change and shifts are smooth and clean.
U sure noise is from tranny and not somewhere else?
Old Mar 16, 2011 | 06:38 AM
deezo's Avatar
Yes, there is a breakin period for a rebuilt transmission with new internal parts. I have a rebuilt auto and didn't experience any noise issues with mine just stiff shifting but it has smoothed out with about 10k miles on it.
Old Mar 16, 2011 | 06:48 AM
njmaxseltd's Avatar
Shouldn't be any noise.
Old Mar 16, 2011 | 07:27 AM
ssoles's Avatar
transmission noise
I don't think there should be any noise,noise means wear,not what you want in a gearbox
Old Mar 16, 2011 | 07:38 AM
maxima.713's Avatar
I just put on my rebuilt tranny on Monday. I still can't shift fast or revmatch like I used too. The shifts are a little too stiff. I really hope they get smoother.
Old Mar 16, 2011 | 08:22 AM
mpvibes's Avatar
Yes it does.
Old Mar 16, 2011 | 08:27 AM
mpvibes's Avatar
I'm not sure, it was everything that came in the complete rebuild kit (bearings, seals, synchros, etc.) Is it true when your replacing new parts with the same gears and stuff it has to break in?
Old Mar 16, 2011 | 08:29 AM
mpvibes's Avatar
I picked up the tranny from the shop, I installed my tranny and I used only GL-4 gear oil.
Old Mar 16, 2011 | 10:05 AM
mpvibes's Avatar
My shifts are also stiff, I have to baby it. Does yours have any sound coming from the tranny?
Old Mar 16, 2011 | 10:42 AM
maxima.713's Avatar
yeah i have this little chatter sound on cold start. when it warms up and im driving it stops. I think its my throw out bearing but im not sure
cashoit's Avatar
Im gonna say this...if u test drive a new car with MT, the shifts are smooth and the tranny dont make no noise. by that same logic, since teh tranny is rebuilt and "like new" then there shouldnt be any noise either.
I am thinkin that somewhere in the tranny isnt or wasnt lubricated when the tranny was rebuilt. The shop is not gonna rebuild the tranny again unless it breaks.
Jus keep driving it and break it in. Thats all u can do. UNLESS, its something else.
Old Mar 16, 2011 | 10:58 AM
mpvibes's Avatar
Yeah cashoit, I think thats what Im gonna do. As of today, I have 415 miles on it so far. I'll let you all know how it sounds when I hit the 500 mile mark. Man, when I press the gas and shift in 1st and 2nd it sounds like a R/C car or a Supercharger!!!
Old Mar 16, 2011 | 10:59 AM
mpvibes's Avatar
So u don't hear anything in 1st or 2nd?
Old Mar 16, 2011 | 11:18 AM
cashoit's Avatar
Did u clean the mating surface on the engine and tranny? Jus asking. Any startup issues?
Old Mar 16, 2011 | 11:55 AM
mpvibes's Avatar
Yeah thats cleaned, I don't have any starting issues @ all whatsoever.
Old Mar 16, 2011 | 01:12 PM
maxima.713's Avatar
Nope
Old Mar 16, 2011 | 02:15 PM
synchros were fine. The only thing that was replaced was the bearings in my trans.
If it's shimmed properly there shouldn't be any noticeable noises.
Old Mar 16, 2011 | 04:56 PM
mpvibes's Avatar
Yeah, well lets see when I hit the 500 mile mark. Today, I was driving and the noise is slowly going away.
Old Mar 16, 2011 | 04:57 PM
mpvibes's Avatar
Nope
Did u have a full rebuild or were the bearings just replaced?
Old Mar 17, 2011 | 06:22 AM
maxima.713's Avatar
Full rebuild. Synchros bearings seals
Old Mar 17, 2011 | 11:15 PM
JtzMax's Avatar
Whatchyou say?
Sup man!
Sounds like they pre-loaded the MS bearing too much. Too thick of shims, IMO. The sound you hear is the compression of gear on gear with little room for movement - making shifting stiff and also the noise. Either that, or they may have tweaked a shift rod while in there, bend one of those even a bit and it'll never be right again. Unlikely for that to happen, but hell - anything is possible. I'd be willing to bet that they didn't measure the pre-load and just reused the old shims in the bearing cups. If that's the case and they didn't order shims from Nissan, you got the shaft on your rebuild. Not much you can do at this point - hope it's got a warranty. Syncroz should be ok as long as you used GL-4, (GL-5 will eat the brass over time). The end result you'll find here will probably be something to the effect of - you'll be just fine for 30 - 80k miles and then it's time to rebuild again. lol (thank you Nissan! ) The noise will probably get softer with time but may never go away totally. You can sort of tell by the sound if it's IPS or MS bearings most of the time, or Diff. They all have their own unique sound to them. All of them not so good.
Hope this might help ... think you'll be fine really overall. Can you post a clip of the sound at all ??? Also, what - if you don't mind - did you pay for the rebuild? Drop and pick up ... no R+R at least that saved you some $$$.
Old Mar 18, 2011 | 02:37 PM
mpvibes's Avatar
Originally Posted by JtzMax
Sup man!
Hey Jtz max? Thx for dropping by and giving me your input on this, I greatly appreciate it! You know, I don't think they shimmed the bearings. The noise is slightly still there. As of today, there are 520 miles on the tranny and 1st - 2nd gear sounds like I have a R/C car or a Supercharger (whining sound)! I took my tranny to these guys because they have alot of experience with maxima tranny's, they have done numerous tranny's. They have so much experience with our tranny's, that it takes them 4-6 hours to fully rebuild one! I got the hook up on parts and labor from the owners of the shop ( the guys who rebuilt my tranny) for $450 w/ 6 month Warranty. I will be FIRE A$$ HOT (MAD) if I have to drop this tranny again, take it to them to fix it (which is far), and be without a car. The tranny shifts like new and has no leak. I will try to put a sound clip on here.
Old Mar 19, 2011 | 12:10 AM
JtzMax's Avatar
Whatchyou say?
Well, if it were me, I'd make the drive out there and let them listen to it, see what they say and maybe go from there. $450 is a good price (being that you r+r'd the thing) ... seems fair. You sure you put enough GL-4 in there? How much did you put in it? Hate to say it, but our trans axles are not that hard to rebuild. If they did syncroz too ... in 4 - 6 hrs, that's a bit rough to believe. You have to break down the whole shaft - all gears to get the new syncroz on. But ... as I said, anything is possible.
Old Mar 19, 2011 | 11:26 AM
mpvibes's Avatar
Yeah, I think when I get some time off I will make that trip out there. Yes I did use GL-4 gear oil and I topped it off and made sure it was full (fluid came out of the fill hole). I know you have a thread on rebuilding our tranny's, one day I'm gonna open up my gear box and rebuild one just for the heck of it because I do wanna learn. Thx.
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
I<3 A32's
Sep 10, 2015 11:07 AM
jfl330
Sep 4, 2015 01:44 PM
