SC Problems
Old Dec 22, 2001 | 12:32 PM
bosco500's Avatar
SC Problems
well, i got my SC pulled off to put a new belt on, and i have run into a problem. There are 2 large allen nuts holding the plate to the SC, and 5 small ones. I got the 2 large ones off, but the 5 small ones will NOT come out. I have broke 3 allen bits, 2 allen wrinches, and went at them with an impact wrench. Has anyone else ever run into this problem? If so what was done to remove the bolts? thanks
Old Dec 22, 2001 | 01:29 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
I bought a set of Allen keys from Home Depot (the one with that comes with a handle). Turbo95Max and I put a pipe at the end of the extension to give more leverage/torque and worked it loose.
The second time around when Jane and I worked on the bracket... it was much easier. Good luck.
Old Dec 22, 2001 | 04:42 PM
95GreenGLE's Avatar
pick up a "breaker-bar" from craftsman or something, its a socket wrench without the rachet action. buy an allen key socket for the end of it.
If that doesnt work, put a long a$$ piece of pipe on the end of it for more leverage, like Kev suggested.
I suggest craftman, just because if you brake it, they will give you a new one so you arent out of the money
-Barto
Old Dec 22, 2001 | 05:36 PM
maximus75's Avatar
They put a lot of lock tight on the bolts. I used an impact gun the first time but a breaker bar should do.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
