oil pressure switch question
Old Mar 25, 2011 | 09:18 PM
350zMaximaownr's Avatar
So, looking at the pressure switch, it is loose, and the rubber guard/boot is torn.
Nonetheless, it obviously needs to be replaced, I am hoping this is the total oil leak issue. There is some splatter up higher, and some run-off around undercarriage, but none of the VC;s seem to have any seepage. Already did lower oil pan gasket....
Any thoughts on if anything else needs to be replaced, i.e. the boot?
Old Mar 25, 2011 | 11:48 PM
DennisMik's Avatar
I thought that my oil pressure switch was leaking and then I found that oil was dripping down on it from above - vc gasket. It took me quite a while to see that it wasn't the switch. I ripped the boot in the process, but I have never changed the switch. It's been over a year.
Old Apr 1, 2011 | 07:09 AM
jholley's Avatar
Originally Posted by 350zMaximaownr
So, looking at the pressure switch, it is loose .....
What is the main cause of these oil pressure switches to leak? Is it being loose like he stated? Is the oil seeping through the threads?
I know they only cost $10 at autozone but if looseness or thread leaking is the main cause then I might as well stick with the OEM switch. When changing oil this weekend I'll just throw on some sealant after cleaning it.
Old Apr 1, 2011 | 07:25 AM
cashoit's Avatar
Isnt there a gasket for the switch? Over time it jus gets worn.
Old Apr 1, 2011 | 07:33 AM
jholley's Avatar
Gaskets aren't made for threaded parts. O-rings and washers are made for threaded parts but none of the internet parts stores showed anything with the switch.
Old Apr 1, 2011 | 08:24 AM
cashoit's Avatar
Hmmmm, if its threaded then it shdnt lead. The ECTS is threaded and i cant remember if there is a washer used, but that doesnt leak at all.
OP,
I wd say clean the area and MAKE SURE u not leaking from somewhere else.
Old Apr 1, 2011 | 08:41 AM
luke95gxe's Avatar
OP,
there is a brass washer on the ects
Old Apr 1, 2011 | 09:28 AM
Trini Boom's Avatar
It does. The oil pressure switch doesn't? Maybe I can find a washer to go on with it once I replace mine. Not sure if its leaking because I have to get a full engine wash.
Old Apr 1, 2011 | 10:16 AM
jholley's Avatar
After reading some other online clubs I found that the inside diaphragm fails over time. It doesn't use a gasket nor washer.
I just baught a new OEM oil pressure switch for $9.75 with free shipping on ebay. When I install it I'll just use thread sealant. The PN for this switch is 25240-8996E.
Did any of you guys have to use the special socket designed for this switch or was an extended socket good enough?
Old Apr 1, 2011 | 11:22 AM
bobflood's Avatar
Mine leaked thru the switch diaphram. Deep socket worked fine, the sensor is pretty short. I think I could even get a wrench on it, thought it's been awhile since I did it.
Old Apr 2, 2011 | 04:17 PM
SO, cut off old sensor plastic pieces, no need for deep socket that was MIA, used 26 mm to get oem part off, and then used deep 22mm to get new switch on....used plumbers tape to lock thread seals....small easy fix that in conjunction w doing VC's and Intake gaskets should be end of oil seepage problem...in theory
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
