what happen?? o.0
what happen?? o.0
I put in some control arms. sway bar endlinks and sway bar bushings...now i got wheel rub on full turn -_-. anyone know anything about this? maybe these control arms are a little different. it almost sounds like the brake rotor is grinding.
dust shield would make just a noise. no i didnt get an alignment. (seems like a toe issue) and it seems like the control arm is touching the rotor. (at least thats what it feels like). havent really checked it yet tho
still havent checked it out yet. dont really have time. its seems as if its starting to go away ..(which bothers me cuz idk what the hell it is yet) but avoiding hard turning for now
Get an alignment first. Then check to see if the sound is comes back after that. But you should be good after the alignment. But stop procrastinating and get the alignment done, or else you're going to have more problems, like getting new tires eventually. Or damaging another component.
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
. It is rubbing against rotor most likely. Push away from rotor at the bottom where the lower control arm meets.
