To the guys (or girls) with 3" exhaust
Old Mar 30, 2011 | 07:22 PM
maxispeed's Avatar
Has anyone had any issues with this heat shield after installing the exhaust? Any dragging, rubbing or when hitting speed bumps? Just wanted to know if I have to customize it so it fits properly.
Old Mar 30, 2011 | 09:37 PM
schmellyfart's Avatar
Are you talking about the Cattman 3" exhaust? No issues in that area with mine.
Old Mar 31, 2011 | 04:48 AM
zach-eminem's Avatar
^^^ hey are you boosted if not how can a three inch exhaust help you na
Old Mar 31, 2011 | 06:18 AM
cashoit's Avatar
All the 3" exhaust guys swear by it. SEARCH my good man.
Old Mar 31, 2011 | 09:27 AM
aackshun's Avatar
And to the OP, nope!
Just some banging on hard rights, but that's related to the hangers, and not the heatshield.
Old Mar 31, 2011 | 09:31 AM
Flava_24/7's Avatar
Boosted Panda
I believe there was some talk about this, and many went with upgraded/ stiffer hangers.
Old Mar 31, 2011 | 09:37 AM
On both my Maximas, no issues with that particular heat shield.......because I removed it for weight reduction (and the rest too)
Old Mar 31, 2011 | 09:42 AM
Kevlo911's Avatar
Kevlo for President
Wiz, if you can feel any heat from removing the shields, get this:
http://www.heatshieldproducts.com/pr...ield-mat/76/21
Lots of cars use this stock nowadays(I usually see um on Benz's)
Old Mar 31, 2011 | 08:14 PM
maxispeed's Avatar
schmelly, I did not order the cattman, Im doing a budget build custom set up but im sticking to the original lay out of the exhaust
flava, do you know where to get stiffer ones?
and wiz, have you had any problems with removing that heat shield? from the looks of it, it looks like its covering the gas tank, isnt it?
Old Apr 1, 2011 | 08:03 AM
Kevlo911's Avatar
Kevlo for President
I know people have used WRX polyurethane hangers on their maximas (I plan on getting them eventually)
Old Apr 5, 2011 | 12:03 AM
Thanks for the link Kevlo, much appreciated. Looks like good stuff.
I went with Nismo hangars for the three at the muffler, and a generic one from Napa Auto parts for the B-pipe. The generic one is much stiffer than OEM. The generic ones would work fine for all four of the positions.
As for removing the heat shields, I don't have any issues. Keep in mind, that one of my Maximas is supercharged and heavily modified too. IMO, the exhaust is so far away from the gas tank (too far actually , but that's a whole different story) I'm not worried at all.
Old Apr 5, 2011 | 06:33 AM
matts95max's Avatar
After I put in a y pipe, hi flow cat, and 2.5 inch exhaust, whenever I take corners or curves, I hear something banging down there. I have looked but nothing appears to be touching anything. But when im driving something is hitting something. What would I need to look at under there to find the cause?
Old Apr 5, 2011 | 09:53 AM
I bet it's hitting the trailing arm. Mine hits on slight bumps etc too.
Old Apr 5, 2011 | 12:30 PM
matts95max's Avatar
im gonna check that.
Old Apr 5, 2011 | 09:44 PM
maxispeed's Avatar
Wiz, think its possible to ghetto rig some kind of spaver there or something?
Old Apr 6, 2011 | 05:21 PM
Wiz, think its possible to ghetto rig some kind of spacer there or something?
Sure, I don't see why not. Just make sure whatever spacer you use is meant to be around exhaust piping and is heat resistant. Don't want to start a fire!
The easiest way I think would be to wrap the exhaust with exhaust header wrap or heat wrap like Kevlo posted above just in that area. That's probably what I'll wind up doing too.
Old Apr 7, 2011 | 05:42 PM
maxispeed's Avatar
^^^ sounds like a good idea. So I dont have to worry about my gas heating up or anything if i remove that heat shield? I just dont wanna screw up my car anymore then it is lol
Old Apr 10, 2011 | 01:49 PM
maxispeed's Avatar
bump, gunna be getting it fabbed up soon and was wondering if theres extra in cabin heat with thme gone, if not I'm taking all of em off
Old Apr 10, 2011 | 03:26 PM
I haven't noticed any additional heat inside the car. Ptatohed has also had his off for years, and he's never mentioned to me any additional in cabin heat either.
Old Apr 10, 2011 | 07:23 PM
maxispeed's Avatar
Alright sounds good, thanks man
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
