lower oil pan gasket
Old Apr 2, 2011 | 04:40 PM
WhiteMaxima9600's Avatar
I read the stickies on removing both oil pans, but my lower pan is the one that seems to have all the gunk and grease built up around the pan bolts etc. I can just remove that lower steel pan to replace the gasket right? I was a little confused when I heard that there are two pans May be a dumb question but I like to know before I make a mess of things
Old Apr 2, 2011 | 04:48 PM
350zMaximaownr's Avatar
There will obv be dirt and grime from the road, muchless mine was caked with oil, which is where I thought original leak was coming from....but, yes, pull off replace, new gasket, RTV and seal off, torque bolts...done..
However, note that this may not solve oil leak probs alone...certainly didnt in my case.
GL
Old Apr 2, 2011 | 05:28 PM
Ok, I might try to tackle it on my next oil change then. My car has 215,000 miles on it so the gasket is pretty bad from the looks of it
Old Apr 2, 2011 | 05:39 PM
RA030726's Avatar
I'm nutty for Nissans
There is no gasket, its all RTV grey.
Old Apr 2, 2011 | 05:51 PM
Trini Boom's Avatar
Same thing I was about to post.. I knew I didn't recall seeing any gaskets on the engine except for valve covers in terms of sealing oil.
Old Apr 2, 2011 | 07:12 PM
[QUOTE=Trini Boom;7996784]Same thing I was about to post.. I knew I didn't recall seeing any gaskets on the engine except for valve covers in terms of sealing oil.[/QUOTE
I know they sell lower oil pan gaskets but the factory may use RTV.
Old Apr 2, 2011 | 09:51 PM
highonfumes's Avatar
there is oil pan gaskets ebay i forget which company but they do have it im also about to do this in the next week or so im changing the oil pan it self and the gasket and if it dont stop with that little leak then next is oil pressure switch
Old Apr 3, 2011 | 03:10 PM
yeah advanceautoparts has them to for 7.99 as well as autozone.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
kjlouis
Oct 3, 2015 05:29 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
dcam0326
Sep 18, 2015 04:52 PM
