another lighting question
Old Apr 13, 2011 | 07:19 PM
MaximaMashing's Avatar
Im missing the front dome light in my car and was wondering the bulb type or size. thanks guys
Old Apr 13, 2011 | 07:59 PM
mdliber's Avatar
is that a 194? just pop off that cover with a flat head and take a look
Old Apr 13, 2011 | 08:14 PM
DennisMik's Avatar
The dome light, which is in the middle of the roof is a 3175 (or DE3175). If you are referring to the light(s) by the rear view mirror, that's not a dome light. It is a map light. It is a proprietary lamp and you can only get it from Nissan.
Old Apr 13, 2011 | 09:08 PM
yea its the map light, so there no aftermarket lights i could put in there
Old Apr 13, 2011 | 11:31 PM
maxed_out_99's Avatar
Well... If you really want to get crazy you could remove the contacts from the old build and solder in some LEDs then you would have a completely custom map light
Old Apr 14, 2011 | 12:45 AM
Jayson89NYC's Avatar
intersting
Old Apr 14, 2011 | 12:01 PM
DennisMik's Avatar
You can buy lamps that fit in there, they just won't be as bright, The Nissan lamp is a 10 watt bulb, the others are 3 to 5 watts.
You can get led lamps (BA9 base) but check and see if it is a polarised lamp or not. If it is polarised, you will have to rewire the socket as it is reverse polarity from all other sockets.
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
Blackwind
Aug 5, 2015 06:35 PM
