P0443 EVAP
Old Apr 21, 2011 | 08:30 AM
J2songz's Avatar
P0443 EVAP
It says EVAP canitster purge valve circuit fault so what does this mean far as how to fix this and where do i look on a 99.
Old Apr 21, 2011 | 08:38 AM
DennisMik's Avatar
If you are missing your gas cap, that causes a CEL. Just not sure exactly which one. Fix the obvious thing first. Get another gas cap and clear the code.
Old Apr 21, 2011 | 08:55 AM
Swazey's Avatar
you have a fault in your evap system. could be a vacuum leak somewhere or a faulty sensor.
does your car stink of gas, especially by the drivers side rear tire? probably have a faulty evap sensor on the canister. id check there first.
heres a bulletin on it
Old Apr 21, 2011 | 09:05 AM
J2songz's Avatar
Im getting a cap soon but the code was popping up before i lost my cap which when i decided to see if its the right cap and make sure its closed thats when i found out it was missing.
I do have some fumes coming into the car
Old Apr 21, 2011 | 09:38 AM
Swazey's Avatar
try this
Old Apr 21, 2011 | 09:44 AM
J2songz's Avatar
Originally Posted by Swazey
This looks like it will help thankx
Old Apr 21, 2011 | 06:20 PM
jfbalkcom's Avatar
i had 0443 and i tried so many things that never ended up working. i ended up going to a junkyard and replacing my entire evap system, it was cheap, but difficult.
Old Apr 21, 2011 | 08:04 PM
J2songz's Avatar
I think I just need to change the valve, my only issue is I'm not to sure on where it is on a 99
Old Apr 21, 2011 | 08:16 PM
Swazey's Avatar
the valve is really easy to change. get one from the auto part store and swap it out. also check the wire harness. if it doesnt fix the problem then just return it. keep us posted
Old Apr 21, 2011 | 08:33 PM
J2songz's Avatar
But where is it located on the 99
Old Apr 21, 2011 | 09:10 PM
DennisMik's Avatar
It's on top of the intake manifold, a little bit behind and to the left (as you stand in front of the car) of the metal loop that has the 2 cables for your throttle.
tseng1023
Oct 15, 2015 08:30 AM
bryants95max
Oct 2, 2015 12:52 PM
homeofbacon
Sep 23, 2015 07:17 PM
220k+ A32
Sep 11, 2015 02:18 AM
dcam0326
Sep 7, 2015 07:26 AM
