neep opinions on what to do next
ok. Starting off, I have a 98 SE 5sp with fidanza flywheel, ypipe, PR CAI, and 175k on the clock. I am pretty much on par with alot of the early 2valve GT guys around here but i wanna get more people upset for losing to the ol' 4 door. I know where a DEK is with less miles. Should i buy the dek and refresh the bottom end for possible spray or boost later and swap it in? Or, should I 00vi my DE and refresh the bottom end anyway. I dont really want to do a vq35 swap for my own reasons. With a price to performance ratio in mind, what would you do in my situation.
Next week starts the refresh on routine stuff. (shocks, mounts, clutch, oil). After those I will be starting the slow climb to 275+ whp.
ugh another "xxx mileage on the clock" person....its an odo
275 whp youll need boost in a 3.0
or do a 3.5 swap full bolt ons with cams....but you dont want to for your own reasons...so good luck
For what its worth. The cams on the de are a little better then the ones on the de-k. So IMO i would put the 00vi on the DE engine. If anything buy the de-k and just take off manifolds and what not to slap on the DE.
honestly the stock bottom end of a 3.0 is pretty solid. Ive beaten the ****(spray,8k revs,7.5 daily,low oil ect ect) out of mine with 160k on it with no problems. Id be more worried about the tranny...... Hell i tried to blow my 3.0 before i swapped my 3.5 and i wound up burning the clutch up
I'm leaning towards doing the dumb, but instantly gratifying, thing and going 50 shot, mevi, and jwt ecu. the DEK can wait till the DE pops and if i have to get it, I'm sure its not hard to get rid of a used mevi. Is there any alternative to a jim wolf ecu as far as some timing changes and the rev raise? What is the current choice for our cars as far as PC based tuning software goes? Is it worth it? I know PC based tuning would be better in the long run for boost/more spray.
Please no trolling. I just want straight answers. And yes i have searched. I just want individual opinions based on my options and goals.
You havent searched enough........
Emanage ultimate......
And dont go mevi just get a 00VI. Your pretty much doing the same amount of work, but you will loose low end power with the mevi.
REDinLV
Aug 15, 2024 12:30 AM
dvcamp
Sep 18, 2015 10:17 AM
