Help, my idle is nuts, car drives itself to 25 mph
Old Dec 24, 2001 | 12:42 PM
Max8MyCash's Avatar
Donating Maxima.org Member and Maxima.org Sponsor
Ok, this has been getting progressively worse. On my 99 GXE auto, every time I start the car, put it in drive, it jumps to like 1200RPMs, and I can literally let the car just cruise on its own. What is going on, even if I rev it, and let it drop, it only drops to about 1100 or so, way too high. After driving around for about ten minutes or so, this stops happenning? Any clue anyone?
Old Dec 24, 2001 | 01:00 PM
Sarah99GXE's Avatar
Maxima Princess
Well my answer doesn't really help you, but my car kinda does the same thing. I've even had my idle lowered, and I can still let off the gas and it will cruise on it's own up to about 20 mph...i'm constantly hitting my brakes in stop & go traffic becuase my car wants to drive forever.
Old Dec 24, 2001 | 01:11 PM
NYCe MaXiMa's Avatar
maybe your throttle cable is getting stuck?
So when you are standing in "P" mode, it's at 1,200 rpms?
no check engine light right?
Old Dec 24, 2001 | 01:18 PM
Max8MyCash's Avatar
This I haven't checked, and no there is no check engine light. This has gotten worse AFTER I installed my Y-pipe about five months ago from Stillen.
Old Dec 24, 2001 | 02:43 PM
nizmo's Avatar
Similar Problem
I have kind of the same thing happening except that mine is a 5spd and its normal when I start the car and idles ok but when I drive I notice sometimes that after driving around 40mph or more I would stop at a red light and put the car in neutral and idle is fcukin crazy at around 1700RPM. Then I'm driving and it returns to normal by itself. I was thinkin the throttle cable too. I'm gonna check it out tomorrow. What do you guys think??
Old Dec 25, 2001 | 12:18 AM
Max8MyCash's Avatar
Yeah, it feels like you can't make your car stop trying to go...
really really odd...
Old Dec 25, 2001 | 12:21 AM
Nismo's Avatar
try popping the hood when the engine is on and check to see if the butterfly is stuck open and rev it up from under the hood to check if there is any sticking
Old Dec 25, 2001 | 04:05 AM
crazy4maxima's Avatar
lol
[B][I][U][SIZE=3][FONT=courier new][COLOR=blue] My max once you let go of the brake peddal it goes 5 mph..lol
Old Dec 25, 2001 | 06:28 AM
Sprint's Avatar
make sure you clean the throttle body
Old Dec 25, 2001 | 08:38 AM
Ginuwin3112
make sure ur motor isnt smoking crack or anything...or doing speed lol
Old Dec 25, 2001 | 11:22 AM
Keven97SE
Check your cold idle idle mechanism. There's a thermostat built into the base of the throttle body that increases the idle rpm of the car until the it warms up enough. Once warm, the thermostat pulls back into the throttle body and allows the throttle "wheel" to rest on the idle stop.
Basically, you just need to loosen a set nut, turn the screw sticking out of the cold idle thermostat, then retighten the set nut.
Hard to explain, but if you have a field service manual, you should find an explanation on how to adjust it.
Old Dec 26, 2001 | 04:27 PM
Max8MyCash's Avatar
Thank you. I will look into that Keven.
Old Dec 26, 2001 | 08:13 PM
Tai Mai Shu Jr.'s Avatar
Dammit you beat me...
YEah i would also say just try and get some TB cleaner, cause that is most likey the problem
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Gsantos79
Aug 8, 2015 07:41 AM
