Car Vibrates Hard when Parked!!!!
Old May 6, 2011 | 07:12 PM
sspomonag's Avatar
I just recently changed the oil, threw some seafoam in gas tank, cleaned maf with TB cleaner changed fuel filter and TRIED cleaning egr valve but failed Ohhh also changed the Egr Temp Sensor since i broke it. The Egr Sensor was replaced with one from a junk yard maxi. So i just decided to quit and put everything back. Now the car when parked vibrates and i could really feel it. It also vibrates when im at a stop light. But the car drives fine. What did it do wrong?? Can somone help??? Im taking a long trip tomorrow and i want to go in the safest conditions with my family onboard Thanks alot
Old May 6, 2011 | 08:15 PM
VQ'rInWLA's Avatar
I think the issue really is you using tb cleaner on the MAF. Try resetting ecu and see if that does anything.
Old May 6, 2011 | 10:37 PM
FallenOne's Avatar
Well, Heres a List. Check these things report back.
1. Any Idiot Lights? Pull Codes.
2. Unplug your MAF, Start your Engine, Does Problem Persist?
3. Check Throttle Position Sensor resistance. 500 when Full Closed 4000 When WOT.
4. Misfiring? Pull coils, One At A Time.
Old May 7, 2011 | 07:10 AM
joseph.mcgowen's Avatar
How do you check your coils
Old May 7, 2011 | 09:59 PM
FallenOne's Avatar
Well, for starters you click the link '98 FSM' in my sig and download the Factory Service Manual.
Than you either use the Factory Methodology or the one i shamelssly ripped from SKORPiO. Thanks SKORPiO.
Originally Posted by SKORPiO
In order to test the coil, take it out. Measure the resistance in the following manner:
POS to 1 and NEG to 2 -- should show infinite resistance
POS to 2 and NEG to 1 -- should show continuity but not zero ohms
POS to spark plug and NEG to 1 -- should show infinite resistance
POS to 1 and NEG to spark plug -- should show infinite resistance
Connector number 3 is a trigger and is not measurable.
Connector:
___|--|___
| 3 | 2| 1 |
If any coil shows otherwise than it sould be replaced.
If I remeber correctly, the resistance between pin 1 and 2 was about 16- 21 ohms on my 96' but dont quote me on that. I did it long time ago.
Hope it helps.
Old May 8, 2011 | 08:53 AM
My bad i didn't see the link, but thanks ill test them tommorow
Old May 9, 2011 | 07:21 AM
cashoit's Avatar
hey wait a min....
U cleaned the MAF wit TB cleaner??? I think that might be a no-no.
I have always used two different cleaners: MAF cleaner and TB cleaner
Old May 9, 2011 | 08:20 AM
sspomonag's Avatar
Originally Posted by cashoit
hey wait a min....
Ok i pulled codes. P0325 P0174 P0110 and maybe two more leading to thr knock sensor ill find out about the other codes when i scan it again once i get back to killafornia
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Trin1j23
Aug 12, 2015 08:31 PM
