Headlight Bulb Removal Problem
Lens Cleaning Problem
I finally got the 10mm socket for my wrench and was able to remove both headlights. I thought I was in the clear to change the bulbs, but there seem to be two long rods sticking out the back of the each cover that hold it to the back of the headlight assembly. I attempted to remove the rods, and the plastic ends that are shaped like nuts snapped... What do I do?
5/21: Got it open but I can't get the white residue off (from the exploded bulb). I tried water and soap, alcohol, and white vinegar but still nothing. Any ideas?
The things you broke were to aim your headlights. I don't have any advice for ya to getting those back on.
You didn't have to remove them to change your headlights. In fact, you didn't have to pull the headlights to remove the bulbs.
I need to get inside of the compartment to clean it out; there is debris in there from an older bulb that exploded (even a dried liquid like substance on the base) and it is making one of the headlights look foggier than the other.
Found the solution here: http://forums.maxima.org/1745286-post2.html
Yeah, you could try wetsanding, but if it did melt the surface of your lens. You might as well get used ones....buff those clear. Or, buy R34's for $110.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
sdotcarter
Sep 2, 2015 09:53 PM
