Fuel injector question.......
Old May 24, 2011 | 12:48 AM
Boothers96's Avatar
Hey, i had to change the number 4 cylender injector and after screwing the cap over the injector on the rail i noticed it didnt sit as low as the other two injectors in the rail. i had expected the cap to squeeze the injector and O-rings into place but it didnt. Fast forward to everything put back together, there is gas leaking out of the top of the injector around where it meets the rail.
Heres the question: can i use a screwdriver/hammer and gently tap on it to push it down into place or will i mess up the injector? what should i do.....
Old May 24, 2011 | 06:53 AM
luke95gxe's Avatar
first off do you have the right injector if you do remove the injector and put a lil bit of oil around the o ring to help it seat if the one on there isnt damaged
Old May 24, 2011 | 07:32 AM
cashoit's Avatar
^^ yup
It is supposed to seat properly. Maybe the parts store mistakenly gave u the wrong one. Compare the new one to the old injector and see if they similar in size.
Old May 24, 2011 | 12:25 PM
Boothers96's Avatar
ya, I didn't have the money for a new one so i pulled the front rail off a 96 at a local pick n pull. All the injectors ohm tested well so I know its the right part
Old May 24, 2011 | 12:26 PM
Boothers96's Avatar
ya, I didn't have the money for a new one so i pulled the front rail off a 96 at a local pick n pull. All the injectors ohm tested well so I know its the right part...ill try the oil and see if that helps
Old May 24, 2011 | 01:11 PM
cashoit's Avatar
ok well as u know the injector supposed to seat properly. Disassemle and align properly
ohm test should be 10 -14 ohm
Old May 24, 2011 | 06:12 PM
Boothers96's Avatar
Thanks ill give it a shot when I get home from work....n ya the ones I have in there now (cyl 2 4 n 6 at least) are all testing right around 12ohms
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
