front crankshaft
Old May 30, 2011 | 02:05 AM
Perseus's Avatar
front crankshaft
alright well for the first time we took a good look under the hood of my 97 gle. found out that there's an oil leak(for sure oil and not other fluids) coming from the front on the passenger side, somewhere high up. read around and found that it's likely the front crankshaft seal
if this all sounds right, could someone please show me a diagram/give instructions on how to gain access to and replace the seal
another thing i noticed is that the plastic accordion things on the shocks are completely deteriorated. if someone could tell me the name for those so i could research them that would be great lol
Old May 30, 2011 | 03:46 AM
adroitcaptor's Avatar
Download the FSM. It is hosted on the NICO forums. It is not a simple issue.
How 'high up' is this leak; where in regards to the front or rear bank?
The dust covers on the shocks are not nec. However they do prolong the life of the shock. Unless you are replacing them or feel they have a good amount of life left, pointless.
Old May 30, 2011 | 12:06 PM
Perseus's Avatar
thanks for the fsm. oil is collecting down close to the passenger side front tire, and it's coming from between the engine and fire wall or around that area
as far as this not being a simple issue...that's fine. we've swapped engines with the limited tools in our garage before so we're down for anything lol
Old May 30, 2011 | 12:30 PM
Perseus's Avatar
what section would the crank be under? can't find what i'm looking for
Old May 30, 2011 | 12:58 PM
tigersharkdude's Avatar
Rear Valve cover gasket..
is it to the rear of the tire? or more towards the front? Could be a number of things right there. Common leaks in the area
Rear valve cover gasket
oil pressure sending unit
not sure of others
Old May 30, 2011 | 01:43 PM
Perseus's Avatar
to the middle/rear parallel to the tire. oil is dripping off the 3 bolts attached to the suspension closest to that tire
Old May 30, 2011 | 06:53 PM
RA030726's Avatar
I'm nutty for Nissans
You lost me from the begining. You have a leak from up high and you think its the front crankshaft seal? There is only one crank shaft and its in the block. The crank shaft oil seal is low and dead center at the bottom of the engine behind the crank pulley. If youre thinking camshaft seal then youre still wrong as there arent really any. There is the valve cover gasket. That is prone to seeping but not driping. But then you say its dripping from the suspension....? Again lost. Are you talking about the driveshaft carrier bearing? Maybe some pics would help.
wyobbagy
Jan 3, 2023 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
6spd4dsc
Mar 4, 2016 05:19 PM
Hdnseek
Sep 9, 2015 05:55 AM
