Gas Smell in Cabin! Strong!
ok, for a while ive noticed a SLIGHT smell of gas when i sit idling for a long time, IE drive thru, waiting for someone, long red light etc....lately its gotten worse. The gas smell is strongest with car on, warmed up, and AC ON.
Things ive checked.
Looked around underneath the car while running for visual drips/leaks - nothing.
Sniffed around car/under hood while running - nothing.
Exhaust smells fine, not like the cars running super rich.
Codes, Scanned and nothing comes up, no exhaust or evap.
Inspected Lines, Rail, Injectors. They dont look cracked, wet, leaky.
Pulled rear seat bottom and inspected fuel tank lines, pump assbly gasket, etc.
Im at a loss for ideas.
Things ive checked.
My Honda did this an it was simply solved by changing my gas cap, go get a new one an see what happens if anything you have a new gas cap. As the car is running the tank get pressurized an forces the fumes out of where ever it can so my Honda forced it out the gas cap put a new one an voila no more gas fumes
Will try fuel cap tomorrow, however every fill up i get the depressurization of air sound of sucking of air when i unscrew the cap. Idk if that means its pressurizing well.....also thinking about this....ill try unscrewing the cap in the morning before pressurizing the system to see if it holds the pressure.
And what would i b looking for around the manifolds.....how does that tie in?
O and i recently replaced fuel filter too btw....
this happened to me it was the hose on the fuel rail it was leaking only when the car was cold cause when its hot the gas is evaporating quickly so other then that thats it that was my problem...... and question does it smell like that all the time or when u turn on heat in the car ?????
i think i may have it figured out....first of all upon more complete inspection i saw that one of my injectors had developed a small leak under the rear of the cap and was barely noticable. ok....replace o-ring, and leak gone. Still have a little smell and i think its the rubber hose mating the front and rear rails together. It looks wet all the time, not leaking/dripping, just looks wet. Idk if its developing small cracks or what but its and easy fix so ill give it a shot.
Thanks maxispeed, i checked those connections out and theyre dry as a bone.....buuuuuut
right there, like i thought, the 3in hose connecting the front and back rail just to the left of where the intake mani meets the lower plenum. Sweet!
AaronL
08-08-2020 10:31 AM
06-06-2017 02:01 PM
