Weird ECU code for a 99 SE
My engine light came on and I checked the ECU code and what I obtained was a 5-12 (5 long blinks and 12 short blinks). I used the ECU decoder and there is no interpretation for a 5-12.
I was wondering if anyone out there has ever run into this ECU code.
I have a 99 Maxima SE with auto.
Any help would be great.
Thanks!
Thanks!
Re: Weird ECU code for a 99 SE
Thanks!
Thanks!
DTC 0512
Diagnostic Trouble Code 0512 points to a problem with the rear Oxygen Sensor. The Engine Control Module detects this malfunction when an excessively high voltage from the sensor is sent to the ECM.
The possible causes include:
- Electrical Harness/Connectors
- The sensor itself.
Re: I had the same code before.
Originally posted by 1MAX2NV
I believe it's the right rear bank o2 sensor. I have to look at my FSM again.
Thanks.
Originally posted by Kyle7475
how do you tell what the ecu code is???
Re: Re: I had the same code before.
Do you remember what you did to fix it? Did you take it into the dealer or was it a do-it-yourself job?
Thanks.
Thanks.
Also .. the Rear O2 sensor affects no form of performance on your car.. so its not a RUSH job.. you can get around to it when you feel like it.. sensor usually go for $65 - $110 from the dealership.. and no matter how hard it is.. the dealership is going to rip you off on labor.. its not that hard to do.. if you feel like attempting it.. go ahead.. its easier than changing spark plugs..
bosch sensors are good
I did the repair myself. The part is about $100 from a discount Nissan dealer ie. Courtesy, Maxwell. The 1999 cali-spec is alittle different than other 4th gen. There are two rear O2 sensors. One located on the pre-cat and the other one is part of the Y-pipe. Here's the part number 22690-4L000. It will have a white insulation sleeve on it.
Thanks.
Thanks.
Re: Re: Re: I had the same code before.
I'm going to wait til the light comes on again and then I'll do the switch. Just too lazy to do it now.
Thanks again.
Originally posted by Ginuwin3112
How do u do the self diagnostic for a 99 SE-L Auto?? On my ECU the dial is for the "ENGINE IDLE SPEED" ??? help?
It appears that the 4th gen 99 Maximas have different text than the other 4th gens.
Hope this helps.
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
