Universal Boot
Old Jun 23, 2011 | 07:02 PM
bassmann's Avatar
Universal Boot
Hi,is their a universal boot to cover the rack and pinion boot that is damaged? If so who sells them? Please help if you can.
Bass
Old Jun 23, 2011 | 10:41 PM
max ride 41's Avatar
cheaper and easier to replace axle than to do just the boot.
Old Jun 24, 2011 | 04:54 AM
ajm8127's Avatar
But the problem is the steering rack boot.
If I were you I would just buy a new boot. If you take careful measurements, you should be able to get the tie rod adjusted to the same length as it was when you removed the outer tie rod end to do the boot. Use some part of the tie rod as reference, for instance where the flats are cut on the rod for a wrench. I can't see it taking more than a hour from jacking your car up to torquing the lugs.
knight_yyz
Nov 1, 2015 01:34 PM
londonflu
Sep 19, 2015 02:33 PM
followthadollar
Sep 17, 2015 06:31 PM
carid
Sep 9, 2015 05:06 AM
