Too much NOS= cooked motor
Old Dec 27, 2001 | 08:16 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
The other day I was driving and some guy in this saturn was speeding up so I used NOS(100HP) and lit the tires up passing him. I only used it for about 2-3 seconds and my car began idling around 5-600 rpm and was shaking. It runs fine but idles rough and I have alot of blowbye out of the valve cover. Any clues what might be the problem. I checked the coil and if I unplug the injector on that cylinder (front center) it is about the same.
Old Dec 27, 2001 | 08:36 AM
SteveChicagoSC's Avatar
Re: Too much NOS= cooked motor
What do the spark plugs look like?
Old Dec 27, 2001 | 08:38 AM
Sprint's Avatar
check your plugs and clean your TB..
mine is idling wierd and making weird noises too.. (100 shot)
Old Dec 27, 2001 | 08:45 AM
njmaxseltd's Avatar
You may have cooked or broke a valve. The blowbye (good clue) your seeing may be the cyliners compression (or lack of) coming up the valve guide. Do a compression test. If that cylinder is dead, your going to need a valve job!
Old Dec 27, 2001 | 09:16 AM
Synki's Avatar
Make sure you dont have any metallic flakes. The black specs are normal from carbon.
With NOS, you build up a lot more carbon in teh motor.
I had the idling problem too and used a full can of TB cleaner is idle is smooth & normal. Good luck w/ you prob & i hope your motor isnt shot.
Old Dec 27, 2001 | 09:21 AM
Sprint's Avatar
probably bent valve spring like njmaxseltd said before
Old Dec 27, 2001 | 09:26 AM
Max4Speed's Avatar
www.autotalk.com
the most stupid thing to do in this car world = put NOS in your car
Old Dec 27, 2001 | 09:28 AM
Sprint's Avatar
you are treading thing waters now my friend
Old Dec 27, 2001 | 09:30 AM
Max4Speed's Avatar
www.autotalk.com
no $#!T? but i think thats how it is
Old Dec 27, 2001 | 09:33 AM
Sprint's Avatar
Old Dec 27, 2001 | 09:36 AM
Max4Speed's Avatar
www.autotalk.com
cheapest way to smoke other maximas
Old Dec 27, 2001 | 09:39 AM
tifosiv122's Avatar
leave the dry and go wet...
Erik
Old Dec 27, 2001 | 09:43 AM
SuDZ's Avatar
You running a wet setup?
SuDZ
Old Dec 27, 2001 | 09:46 AM
tifosiv122's Avatar
SuDZ
Yes I am...
Erik
Sprint's Avatar
Old Dec 27, 2001 | 09:48 AM
Max4Speed's Avatar
www.autotalk.com
hey sprintmax... how much a stillen v2 supercharger will cost INSTALLED?
Old Dec 27, 2001 | 10:01 AM
Sprint's Avatar
i have been quoted for the v2 for the 95 - 98 for $3390
most shops will charge from $600 - $1200
so that leaves a price from $4000 - $4400 it really varies.. I would scout a shop in your area first before you commit to buying an SC.. no sense in buying it if you can't install it
or you can take the brave route like Matt, delio and others and do it yourself
oh and if you buy an SC.. buy a smaller pulley from vortech at the same time.. might as well go higher boost now.. than to have to pay to have it installed later on..
Old Dec 27, 2001 | 10:06 AM
Max4Speed's Avatar
www.autotalk.com
most shops ...
damn thats like 10 mods i can do to my car if i dont get SC.. how much HP gain?
Old Dec 27, 2001 | 10:09 AM
Sprint's Avatar
supposedly 60 to the wheels intially... then you start playing with smaller pulley's the numbers go up.. you just won't have that much torque as you will horsepower..
10 mods that won't equal the power.. unless you get.. well .. lets leave that one alone..
Old Dec 27, 2001 | 10:11 AM
RastaManMax's Avatar
NOS
Old Dec 27, 2001 | 10:12 AM
Jeff92se's Avatar
I'm needing a caw
Lotsa blow by from the valve cover? Hmmm. Make sure the offending spark plug isn't broken. I hope you didn't toast a piston ring. Wouldn't hurt to do a compression check. If that is inconclusive, you can go ahead and get a leakdown test. As others have said, you could have also bent/burnt a valve
Old Dec 27, 2001 | 10:16 AM
Scruit's Avatar
U wanna try me young boy?
cheapest way to smoke other maximas :roleyes:
Apparently, it's also the cheapest way to smoke your own Maxima.
I did hear of a SHO guy running a single NOS injector into his intake and he had exactly the same symptoms. Something about the spray not reaching one particular cylinder, leaning it out and burning up the valves. His next two projects were top-end rebuild and wet (injector-per-cylinder) NOS setup , instead of the dry / cheater system.
Old Dec 27, 2001 | 10:17 AM
Sprint's Avatar
so now i go from "Sprite" to "Others"?
Old Dec 27, 2001 | 10:21 AM
tifosiv122's Avatar
Again, wetter is better. That is direct port though...way too expensive imo and too hard to remove and mask up...
Erik
Old Dec 27, 2001 | 10:41 AM
tifosiv122's Avatar
Stillen quoted me $3400 shipped for a V1 for my 96...I was just curious. If that is Stillen's price, I am sure it can be found cheaper.
Erik
Old Dec 27, 2001 | 10:46 AM
Sprint's Avatar
Erik
good luck.. thats the best price out there.. prices depends on which Stillen rep you speak to.. talk to Adum Hhume and you get the best prices.. ask Avalon if they can beat that price
Old Dec 27, 2001 | 10:51 AM
BluFlame's Avatar
If the S/C kit was made in china, we would all be driving fast maximas.
Old Dec 27, 2001 | 10:58 AM
tifosiv122's Avatar
Yes...all the dry one's will come around some day...
Erik
Originally posted by rOaD bEaSt
Let me tell you something I'm sure that you burned spark plugs with your 100 shot I don't think that the maxima is that east to bent a vaulve I bent the vaulve once because I missed the shifting and I was hitting the rev limiter for like 2 sec with NOS and the gear was at normal mode ..
I was using 135 HP wet system ..
If I hear you car sound I will know what it is ?
If you remove the spark coils and you don't feel that the car change then it's something else than the spark plugs and the vaulve .
And I'm hearing about cleaning throttel body I don't think that if you are using nos you will find these dirty things
Maybe this is because you are using dry kit .
My friend has a 300 zx 84 model he used a 53 jet NOS and he bent a vaulve but he missed the shift too, he was using dry kit at the begging but after switching to wet he didn't have this problem
Old Dec 27, 2001 | 11:01 AM
Sprint's Avatar
Erik
nope.. because i will have SC and NOS someday.. and dry kit is easier to work with.. because with an SC i am not going higher than 50 shot..
Old Dec 27, 2001 | 11:08 AM
Sprint's Avatar
The HP that you wanna get it from super charge you can get it from NOS then why do you wanna use both ?
because i don't feel like spending $70 refilling two bottles everyweek..
Old Dec 27, 2001 | 11:13 AM
Sprint's Avatar
Aren't you intrested for the middel east intake runner or you don't care about this **** ?
Maybe you are always looking for the real HP ..
doesn't matter.. still have to refil the bottle...
Old Dec 27, 2001 | 11:29 AM
gtr_rider's Avatar
192.168.1.1
OK someone please advise me of what the wet and dry systems are please.
Old Dec 27, 2001 | 11:31 AM
Max4Speed's Avatar
www.autotalk.com
Old Dec 27, 2001 | 11:53 AM
Sprint's Avatar
http://www.clubmaxima.com/articles/N...ForParties.php
Basically Wet System.. Nitrous and Fuel are injected into the engine..
on a Dry kit.. the Nitrous kit uses the factory fuel pump and injectors to supply extra fuel but upping the pressure using the Factory Fuel Pressure Regulator...
Old Dec 27, 2001 | 12:30 PM
tifosiv122's Avatar
That part does suck...I have gone through 8-9 bottles and I have only had it a few months... and for 1 month I have been waiting for a new Nitrous Line...mine split in two during the last Maxima meet in New Brunswick...uhh...
Erik
Old Dec 27, 2001 | 01:26 PM
SuDZ's Avatar
Erik
How often you spray?
SuDZ
Old Dec 27, 2001 | 05:08 PM
mtrai760's Avatar
'Trynna' is not a word
So what happened to your car already! Is it broke or what?
Old Dec 27, 2001 | 05:43 PM
TILLEYS99's Avatar
Thanks for all your suggestions I had my dad check it today hes a mechanic and he said it seems like the skirt of the piston gave way due to over revving which makes sense because i dont have a window switch to kill the NOS at a certain rpm so I guess not buying that cheap part will now cost me some $. I found a motor today with 106,000 miles for $560. I think I will purchase it and rebuild and port and polish the heads and upgrade the head gasket to copper. BTW I have a wet kit. Also my car over revved since I have no window switch and was spinning the tires like nothing.
Old Dec 27, 2001 | 05:47 PM
Sprint's Avatar
ughh.. i hope thats not my issue i do have a window switch though
Old Dec 27, 2001 | 06:04 PM
TILLEYS99's Avatar
how bad is yours
