Shaved rear emblems
Old Dec 27, 2001 | 09:17 AM
spamman's Avatar
Shaved rear emblems
I removed the side badges on my 96 Mustang and was wondering if I could do the same with the rear "maxima" and symbols on the trunk of my 97SE. Is it as easy as:
use fishing line or floss to cut through the adhesive
and then remove the remaining adhesive with like "Goo-Gone"
and then wash and wax?
Do these emblems have alignment holes in the body like Ford?
Thanks all: e3 - spamman
Old Dec 27, 2001 | 09:18 AM
clee130's Avatar
Re: Shaved rear emblems
No holes.
Old Dec 27, 2001 | 09:19 AM
Vyrus's Avatar
That's it...
You got it. It won't leave any holes at all, except for the FRONT Nissan badge. Rear has no holes whatsoever.
-Cyrus
Old Dec 27, 2001 | 09:52 AM
SuDZ's Avatar
Re: That's it...
-Cyrus
Exactly. They did not add any holes on the back until the 5th gens.
SuDZ
Old Dec 27, 2001 | 10:16 AM
RastaManMax's Avatar
Who here has done it using that method? Do you guys have any pics? Please list all the materials you used and any helpful links. I want to do that myself, but i don't want any color fade where the emblems used to be or no roughness. Thanks
Old Dec 27, 2001 | 10:21 AM
clee130's Avatar
Lots of people used the method above. And there will be no color fade. Although it's best to do it if your in a warm climate or have a heated garage. Cold emblem glue is nearly impossible to take off.
Old Dec 27, 2001 | 10:23 AM
spamman's Avatar
Rasta: I did this on a 5 year old Mustang and the color was VERY close. If you got up close about 6 inches away you could pick out a faint difference but the car was dark green. I think the lighter car colors would have less variation that can be perceived. I also did not do a very good job of waxing the area and surrounding paint. Other comments? peace: e3
Old Dec 27, 2001 | 10:57 AM
Thanks for the quik replies!
Old Dec 27, 2001 | 11:34 AM
krzymax's Avatar
Maxima owner since 2000
just remember to wax the sucker. it'll look good as new
Old Dec 27, 2001 | 12:59 PM
BlackMax97's Avatar
My Emblems
If you find that you can see some ghosting after removal, try some Goo Gone. My emblems were shaved before I got the car and the person didn't wax the back after they were removed. I tried Goo Gone, waxed and all was great!
Old Dec 27, 2001 | 01:29 PM
SuDZ's Avatar
Re: My Emblems
Alot of people find out that stuff works really nice for them. How long was it shaved before you used it?
SuDZ
Old Dec 27, 2001 | 04:20 PM
JoesMAX's Avatar
i shaved my nissan emblem in the back and you can see the difference in color slightly... epsecially at night with someones headlights on the back of my trunk. thats why i didnt shave off the maxima yet.. maybe ill try the goo gone next time i wash my car
Old Dec 29, 2001 | 09:11 PM
meezer's Avatar
Shaved clean
I just shaved them all off the trunk. I used dental floss and 3M adhesive remover to get the glue off. I then used 3M medium-grit rubbing compound to get rid of the shadow and wax to shine. You can't tell they were ever there. Next step was to paint keyhole. I used touch up paint in the little tube vs. spray. Three coats and it dried nice and smooth. I then lightly wet sanded with 1200 grit and buffed. Nice.
meezer
95SE 5sp
Old Dec 29, 2001 | 09:22 PM
88MaximaSE's Avatar
If you use a hair dryer and fishing line it is much easier. I used that orange based goo gone and it worked without waxing the car. it actaully got rid of the pain inthe *** wwater marks that were developing in the rear
Old Feb 2, 2002 | 09:55 AM
RPMaxima's Avatar
Ok, I did a search, and this is the exact problem that I am facing. You can see the color difference pretty bad at night, especially the outline of the emblems and letters. When I run my finger over it, I can't feel the lines, but when I run my fingernail I can feel them. I can't tell if they are sticking out, or it is like a scratch, so I am not sure. I've tried washing, waxing, and buffing, but I still can' seem to get the shadow to go away a night when someones headlights are on the back of my trunk. Can tell me anything I can try to get rid of this? Did anyone have a similar problem and solve it? What kind of stuff should I use in the process? Thanks!
Old Feb 2, 2002 | 11:45 AM
sil SE's Avatar
how do you remove the front emblem?
Old Feb 2, 2002 | 11:48 AM
krzymax's Avatar
don't. it'll leave two holes like those hondas
Old Feb 2, 2002 | 01:01 PM
sil SE's Avatar
yeah but im trying to paint the hamburger "buns" red.
actually i did already but without removing the emblem first WHICH WOULDA MADE IT BETTER AND EASIER!! DOH!
Old Feb 2, 2002 | 01:07 PM
RPMaxima's Avatar
Sounds a little ricey to me, but post pics when you are done. They might look pretty good, and I haven't seen any Max's with red emblems on. Good Luck!
Old Feb 2, 2002 | 01:09 PM
sil SE's Avatar
nah not ricey. maybe . but you know the nissan racer emblems where the hamburger is in blue and the buns are in red? its hot
i coulda done a MUCH better job - dammit
Old Feb 2, 2002 | 07:06 PM
sil SE's Avatar
someone tell me how to get it offfff
..thanks.
Old Feb 3, 2002 | 07:35 AM
RPMaxima's Avatar
I doubt this is how most people would recommend doing it, but I took my front one off with 2 screw drivers on both sides lifting it equally as to not break the things sticking out of them. Hopefully this helps.
No one has ever experienced a problem like this? You can see the color difference pretty bad at night, especially the outline of the emblems and letters. When I run my finger over it, I can't feel the lines, but when I run my fingernail I can feel them. I can't tell if they are sticking out, or it is like a scratch, so I am not sure. I've tried washing, waxing, and buffing, but I still can' seem to get the shadow to go away a night when someones headlights are on the back of my trunk. Can tell me anything I can try to get rid of this? Did anyone have a similar problem and solve it? What kind of stuff should I use in the process? Thanks!
Old Feb 3, 2002 | 08:15 AM
sil SE's Avatar
hey rpmax is it tape/glue under the front emblem like the back tho? as well as the two things sticking in there?
Old Feb 3, 2002 | 08:23 AM
RPMaxima's Avatar
I think it once was an adhesive, but when I took mine off, it just looked like goo. Once the emblem is off, it is very easy to remove this goo with your finger. Hope that helps a little.
Old Feb 3, 2002 | 12:10 PM
95maxrider's Avatar
Lightly modded
use CLOTH to apply the goo be gone, because paper towels scratch the paint, and make sure you wax after, cause that helps a lot with the discoloration
Old Feb 3, 2002 | 08:55 PM
boosted95's Avatar
shaved emblems
i shaved my emblems today and after that there was discoloration. i was wondering if there is anything i can do to make it look better. thank you
Old Feb 3, 2002 | 08:58 PM
sil SE's Avatar
Re: shaved emblems
well seems like you have a black max and according to everyone the darker your color the more youll see the difference. but as everyone says, wax that *****h and wait , itll be almost like you couldnt tell the difference.
Old Feb 3, 2002 | 09:02 PM
krzymax's Avatar
when i shaved the nissan emblem, there was a slight discoloration. i waxed the area a couple times and let it set. waxed it again the next day and gave my car a wash. the discoloration disappeared after all that.
matts95max
Apr 23, 2025 10:44 AM
adamgalazka
Feb 5, 2023 08:24 AM
GregL65
Jan 17, 2020 08:01 PM
rbaker100
Sep 6, 2015 02:46 PM
