99 Maxx Cuttin out at full throttle.
Old Jul 27, 2011 | 10:15 AM
TravisCadello's Avatar
ok its done this few times, it happens when low on gas but still have a bit over E line if i floor it racing it runs good all the way till right when it hits 3rd gear then it goes to 4k RPMS and it just cuts out like its starving for fuel and i kept it floored one time while it was cutting out and the rpms stayed at 4 for a sec then slowly went down then the car car turned off.
the only code is for a bad Oxygen sensor.
my 95 maxx didnt do this even when dead empty on fuel so im not sure if thats my issue.
Old Jul 27, 2011 | 10:50 AM
cashoit's Avatar
weak fuel pump or overclogged fuel filter
Old Jul 27, 2011 | 11:18 AM
aackshun's Avatar
Same problem here, fuel pump is going buddy... I bet you have long starts some times too.... Well in my case, you could still have a clogged fuel filter too....
Wait... Why are you getting on it with less than a 1/4 tank anyways???
Old Jul 27, 2011 | 11:26 AM
schmellyfart's Avatar
Is the gas light on when you are doing this?
Old Jul 27, 2011 | 12:04 PM
asand1's Avatar
Um... under acceration fuel moves to the back of the tank away from the pump. Should be common knowledge. Thats why stock cars use baffles and foam. Put more gas in your car.
Old Jul 27, 2011 | 12:51 PM
njmaxseltd's Avatar
The problem exists between the drivers door and the gas pedal.
Old Jul 28, 2011 | 04:21 PM
no gas light was not on. it was right above the Line had about 6 bux in gas in it. and very rare when it has long starts.
Old Jul 28, 2011 | 07:27 PM
aackshun's Avatar
Either way, you're too low on gas....
Old Jul 28, 2011 | 08:09 PM
Yeap
Old Jul 28, 2011 | 09:16 PM
seanwn's Avatar
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
Socalstillen
Sep 26, 2015 12:01 PM
