Flex pipe replacment
Old Aug 2, 2011 | 09:41 AM
ik95's Avatar
Hi all i have a 95....my flex pipe is total rusted and tearing apart. Im looking to replace with one of this "alumimun strechable pipes" from autzone...they have few sizes...any one know what size would work for the max????
Old Aug 2, 2011 | 11:22 AM
Get an actual SS flex section off eBay and have that welded in. Aluminum will rust over time and who knows if that "stretchable pipe" will even work.
Old Aug 2, 2011 | 11:31 AM
GarageToys's Avatar
...Aluminum will rust over time...
Old Aug 2, 2011 | 11:57 AM
Nayehi's Avatar
Agree with the above. Alum is hard/expensive to weld in even if possible and clamps leak; almost always. Had same problem with Toyota and did the same thing you are asking. Lasted 2 months. Replacements are rather expensive but in long run save lots of headaches. Try Midas, Meineke or the like. GL
Old Aug 2, 2011 | 01:55 PM
ik95's Avatar
thanks all
Old Aug 2, 2011 | 09:16 PM
pflicht's Avatar
Why not just buy an aftermarket Y pipe (cheapo) with flex pipe already on there? Cost somewhat the same (if you install y pipe yourself vs taking to a shop and having them weld in the new piece) and you gain a tiny bit of performance?
Old Aug 3, 2011 | 10:40 AM
clive's Avatar
100% chingon
Joining any aluminium part to steel results in the aluminium part rotting away really quickly due to electrolytic corrosion. MAZIT = Mg, Al, Zn, Fe, Sn. Aluminium is higher in the series than iron and so it corrodes first. In other words aluminium flex sections aren't going to last longer than 5 minutes.
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
stromm
Aug 27, 2015 04:13 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
