96 maxima shifting problems
Old Aug 5, 2011 | 06:25 AM
asperos28's Avatar
the other day the car worked fine
i went out this morning to go to work and the car started but would not go into gear
the clutch feels normal till u start up the car and then it goes to the floor
i replaced the slave..and it still does the same thing
possible throwout bearing?
or even the pressure plate?
any input would be appreciated thanks
also the car will shift into the gears when off...
Old Aug 5, 2011 | 06:27 AM
aackshun's Avatar
This post may help you...
http://aackshunsgarage.blogspot.com/...utch-line.html
In order of what failed for me...
-Leak in the rubber line from check box to slave
Couple of months later....
-Leak somewhere else/Slave failed
-Replaced the lines and rebuilt the slave, been fine ever since.
Old Aug 5, 2011 | 08:36 AM
cashoit's Avatar
Lines, Slave, or master. Gotta be one of them.
If not then u got a bigger problem.
Old Aug 5, 2011 | 03:10 PM
asperos28's Avatar
i replaced the slave..still nothing
the fork that holds the throwout is rattling like no other when u push the clutch pedal in..
Old Aug 5, 2011 | 04:38 PM
asperos28's Avatar
once the clutch is bled the fork is chattering even more
helppp
Old Aug 23, 2011 | 04:35 PM
irish52084's Avatar
Did you already check the lines and fittings for leaks? Did the slave bleed easily? If so then a leak is probably not your issue. Does the pedal stick or slow to return?
Old Aug 23, 2011 | 04:43 PM
Dark_man_x's Avatar
Take the rubber boot off of the clutch fork and look inside with a flash light. you might be able to see if either the spring clip that holds the fork to the ball is missing or if the fork itself has broken. Other than taking the trans out and looking at everything its kinda of hard to diag.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Trin1j23
Aug 12, 2015 08:31 PM
