Painted my wheel covers
Old Aug 7, 2011 | 10:34 PM
DennisMik's Avatar
My 1997 Max is the GXE model with the plastic wheel covers. Over time, the paint was wearing off of the wheel covers. It finally got so bad that I couldn't ignore it any longer.
As it came off the car.
After washing it.
The paint said to wash with an ammonia based cleaner, which I had never encountered before. But I figured that if they put it in the directions, it must somehow chemically treat the surface. However, I first blasted it with a power washer, then scrubbed it down with TSP (Tri Sodium Phosphate) and then scrubbed it again with an ammonia/water solution.
After painting.
This is the paint I used.
The paint directions say the ideal temperature range is 50 to 85 degrees. I was concerned about that as our night time LOW is 85 degrees. The last wheel cover I painted, the temperature was about 110 degrees in the garage and I had problems. The paint was evidently drying before it contacted the wheel cover and when the paint dried, it felt like 100 grit sand paper. I rubbed it down with 000 steel wool, but I wouldn't be surprised if I have to re-paint that one.
Old Aug 7, 2011 | 11:36 PM
Snypa's Avatar
Great Job. Looks brand new to me.
Old Aug 8, 2011 | 02:02 AM
+1. Nice work!
Old Aug 8, 2011 | 05:07 AM
dundun's Avatar
Good job I need to do mine
Old Aug 8, 2011 | 05:09 AM
phatboislim's Avatar
gorgeous...i thought this was one of those 'paint my hubcaps black' sort of threads. nice hubcap restoration!!
Old Aug 8, 2011 | 05:54 AM
seanwn's Avatar
Looks better lol
Old Aug 8, 2011 | 08:15 AM
DennisMik's Avatar
Thanks guys. I was worried that no one would be able to tell the difference.
Old Aug 8, 2011 | 08:35 AM
ChrisMagee's Avatar
looks great, I've been thinking about doing the same to mine. is the TSP that you used necessary?
Old Aug 8, 2011 | 10:10 AM
danmack34's Avatar
Great work!
Old Aug 8, 2011 | 10:31 AM
Fasteddie01's Avatar
Yes, Those look really great. I di mine a couple years ago ... had to file off some rash first I then put about 5 coats of clear ( one large can) and they still look fine after 2 seasons of snow. I use them for on my winter wheels, but I guess you don't have that issue there P
Old Aug 8, 2011 | 10:35 AM
VQ'rInWLA's Avatar
They came out nicely! Good siht bro!
Old Aug 8, 2011 | 02:48 PM
DennisMik's Avatar
For some reason snow doesn't stick around very long in 100+ weather, but then this pic is from Feb of this year.
Old Aug 8, 2011 | 04:21 PM
Haishun Boi Max's Avatar
looks good
Old Aug 9, 2011 | 02:52 AM
infinimax96's Avatar
Looks brand new again. Might want to spray a coat or 2 of clear over the top to keep them protected from chipping or fading.
Old Aug 9, 2011 | 09:13 AM
DennisMik's Avatar
^^^ That's a good point. Clear coat is something I should consider. The paint claims to be chip resistant, but to what extent. I doubt that the paint was considered for automotive use. The one wheel cover already has tar on it and I'm kind of afraid to try and remove the tar for fear of also removing the paint. I guess this is an experiment in progress.
Old Aug 9, 2011 | 09:19 AM
cjandura's Avatar
i did this last year to my 97.what i learned was yes clear coat them and get a can of flex primer for the undercoating so it stops it from cracking.and let me tell you painting them makes a world of difference in the appearence of the car.
http://www.automotivetouchup.com/spr...-promoter.aspx
Old Aug 9, 2011 | 01:30 PM
Clear coat will resolve that problem for sure. Tar will just come right off without touching the paint.
Old Aug 9, 2011 | 02:51 PM
96MaXiclean's Avatar
wow, looks great... professional like. clear coat for sure though, or you'll be doing this project again shortly.
Old Aug 9, 2011 | 03:10 PM
Shift_A32B's Avatar
Old Aug 9, 2011 | 07:29 PM
DennisMik's Avatar
Any further work on the wheel covers such as clear coating is going to have to wait until the temperature drops to the 85 - 90 degree range that the paint manufacturers recommend. That probably means November. The Krylon paint I used will be getting a good road test in the meantime. The car is a daily driver, getting around 800 miles a month for the next 3 months.
Old Aug 13, 2011 | 10:58 PM
Ejay98max's Avatar
Looks great!
Old Aug 13, 2011 | 11:24 PM
maxprivate's Avatar
Black Lion
Great job, post some pics of those shoes on the Max.
Old Aug 17, 2011 | 12:28 PM
ChrisMagee's Avatar
I have the same caps and mine were starting to look a bit rough so I decided to try this too. I didn't bother sanding or doing anything to treat the surface besides giving them a good cleaning prior to painting, in hindsight it probably wouldn't have hurt to do that though. I used a can of the same brand spray paint the OP had used, but wasn't wild about the color or coverage it had, so I used it as a primer basically. I went out and bought a can of Valspar spray paint from Lowe's, which had much better coverage and consistency. I hit the visible part of the rim behind it with some black spray paint too, just to make it look a little bit better.
Figured I would attach some pictures, ignore my dirty tires, haven't had much time lately to take care of them.
During painting:
On my max:
Old Aug 17, 2011 | 12:39 PM
OP, yours turned out great!
Old Aug 17, 2011 | 12:49 PM
Goomz's Avatar
great results!
Old Aug 17, 2011 | 12:54 PM
Swazey's Avatar
great job. i was going to do this on the wifes jetta but was too lazy and went the ebay route.
Old Aug 17, 2011 | 01:01 PM
Maximumryan's Avatar
Looks good... Now just grab a little brush and paint the logo in the center with red letters!
Old Aug 17, 2011 | 02:03 PM
ChrisMagee's Avatar
I was thinking about maybe doing that with a fine tip black sharpie just to highlight it, red would look weird with my gold max. I'll post pictures if I decide to do it.
Old Aug 17, 2011 | 02:37 PM
cripdyce's Avatar
Great job guys. thats a mighty wheel gap too btw.
Old Aug 17, 2011 | 04:11 PM
ChrisMagee's Avatar
everyone tells me how awesome the monster truck look on my Max is :/ obviously kidding, I just got the car about two months ago and haven't had too much time/money to look into lowering it at all, I would love to in the future though.
Old Aug 17, 2011 | 05:34 PM
Daniel1120's Avatar
Dennis, I certainly didnt expect to see you on hubcaps. They look good.
HOKUSMAX
Nov 13, 2017 04:34 AM
tgreen
Oct 18, 2015 06:18 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
