intermittent lost of steering power - PS belt?
Old Aug 19, 2011 | 09:07 PM
kel456's Avatar
this is going to be a bit difficult to explain. i am experiencing an intermittent lost of steering power if you will. it's like an intermittent tiny fraction of a second feel in a cycle of off/on if you will. it does not feel like a vibration. do you think it's the PS belt?
Old Aug 19, 2011 | 10:26 PM
DennisMik's Avatar
I had a car a few years back that the power steering would lose the power assist for a second or so. It was a loose belt. If you still have the original belt, it's possible you could have a loose belt and maybe even need to replace it. Here is a link to a video about replacing the belt which also shows how to adjust it.
http://www.youtube.com/watch?v=L8c1e...2C64F&index=19
Old Aug 20, 2011 | 09:47 PM
asand1's Avatar
Is the fluid topped off with Dexron III or higher? Low fluid will cause a pulsation (chatter).
Old Aug 21, 2011 | 07:05 AM
johnmax98's Avatar
My fluid seems to be leaking, but I never have to top it off....very weird....
Old Aug 21, 2011 | 03:05 PM
DennisMik's Avatar
Yes, very weird. How long has it been leaking? Where do you think it is leaking from?
Old Aug 21, 2011 | 05:31 PM
Trini Boom's Avatar
Chances are that its not visible to him. It is at the pump itself. I am also losing power steering but only when I parallel park and the car is warm. At cold, it works fine. Plan to replace the pump itself. If the belt was lose, wouldn't it make a squealing noise?
Old Aug 21, 2011 | 07:52 PM
asand1's Avatar
Probably your rear valve cover leaking onto the pump and lines.
lowpost99
Oct 26, 2025 06:53 PM
AaronL
Nov 15, 2020 11:52 AM
mikeg75
Nov 30, 2015 05:12 PM
markevans999
Oct 25, 2015 08:27 AM
RWCreative
Sep 21, 2015 11:01 AM
