Good Idea to drop oil pan and make sure screen is clean?
Old Aug 19, 2011 | 09:17 PM
TravisCadello's Avatar
its a 99 bought with 228k miles and i changed the motor oil to full synthetic mobil 1 high milege day i bought it and a month later added 3/4 of a court of ATF to oil to clean it up. tommorow im doing oil change and was wondering since its such a small oil pan would it be smart to pull down pan and make sure no gunk is in the oil pickup screen?
Old Aug 20, 2011 | 01:22 PM
Snypa's Avatar
I wouldnt.
Old Aug 20, 2011 | 01:42 PM
T-Mon3y's Avatar
You put ATF in your oil?
Old Aug 20, 2011 | 01:46 PM
eSiK's Avatar
How would adding ATF to oil clean the engine??
Old Aug 20, 2011 | 01:57 PM
Trini Boom's Avatar
I am so confused myself...can someone elaborate on this mixture please??
Old Aug 20, 2011 | 02:28 PM
QT1 5MT AE's Avatar
Gram Lights addict
ATF in oil?
http://www.auto-rx.com/
Old Aug 20, 2011 | 02:33 PM
Daniel1120's Avatar
ATF in the oil before an oil change acts as a flushing agent. An old trick of the trade. I would hate to see your faces when I told you that guys with older diesels run an atf/oil mixture in their engine, all the time. Why not drop the pan if you have the time? Cant hurt. I would. But I dont think trying to clean up the engine on a car that old was a good idea to begin with. The atf will loosen up deposits that are actually keeping some seals from leaking.
Old Aug 20, 2011 | 07:55 PM
max ride 41's Avatar
yup, at that mileage your taking a chance on causing seals to soften up and start leaking. "if it aint broke, don't fix it"
Old Aug 20, 2011 | 08:13 PM
QT1 5MT AE's Avatar
Gram Lights addict
yup, chances are the crap is preventing the oil from leaking and once it comes off it starts oozing. and all that junk circulating is bound to block something up. thats why i posted auto rx. it actually dissolves build up and sludge and conditiones the seals.
Old Aug 20, 2011 | 09:08 PM
but at his mileage i would'nt run that stuff. god only knows what'll break loose and jam up. just change the oil and add bg moa oil treatment, i've been doing it for years and it helps to keep the viscosity of the oil stable so it protects the block better against high heat and wear down.
Old Aug 21, 2011 | 10:12 PM
i ended up not doing it i will next oil change. the oil was pretty dark this change, had 3800 miles on oil but u can tell it cleaned some stuff up.
and yes its a old trick from the old school putting ATF in motor oil the last 500-1000 miles of your oil change 1 quart to 4 quarts oil will clean up the motor. ATF has WAY more cleaning agents then motor oil. Google it.
Old Aug 22, 2011 | 03:51 AM
no way and no thanks. i'll stick to what makes sense and works for me....
Old Aug 22, 2011 | 08:58 AM
MikeF's Avatar
Two things.
Rather than using the ATF (usually, high detergent), why not use Sea-Foam to clean the engine? That's what it's designed for.
Dropping the oil pan on the Maxima is surprisingly easy. When I changed my leaking waterpump on my 96 several years ago, I was concerned that some Anti-Freeze had dripped into the oil (rightfully so it turned out). I dropped the bolts on the oil pan and it comes right off. Just use some black RTV sealant to reseal when putting it on. It's literally that simple. Just torque the bolts a little at a time as you go around, don't over tighten them.
By the way, antifreeze in the oil is a BAD thing. It will freeze up bearings rather quickly. I learned that many years ago from an old mechanic when I worked in a Ford garage back in '69.
Mike
Old Aug 22, 2011 | 11:41 AM
Originally Posted by MikeF
Two things.
Mike
damn man, old much??? i was born in 64 myself, thought i was old head around here.
Old Aug 22, 2011 | 02:36 PM
T-Mon3y's Avatar
Ok used on an iron block i can see, but aluminum?
Old Aug 22, 2011 | 05:06 PM
ThurzNite's Avatar
Mike
Seafoam in the oil, right? Not the vacuum line or the gas tank?
Dr J
Old Aug 22, 2011 | 06:53 PM
maxed_out_99's Avatar
I actually did this atf/ oil mix I ended up buying valve cover gaskets but it ran and still does run super smooth I noticed a difference right away
But I had to take it apart a week later
Old Aug 24, 2011 | 12:19 PM
I ran a quart in my mobil 1 for about a month and 900 miles changed it and here i am 120 miles later with new oil no leaks. Yours was probably on its way out in the first place. the ATF just sped it up.
Old Aug 24, 2011 | 12:45 PM
jholley's Avatar
Once a year I just throw CD2 oil detergent in there during an oil change. It's made specifically to clean particles in the engine without eating away those sealants. It sure has kept my VQ running smooth.
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
BobMax
Aug 15, 2015 12:35 PM
maxima297
Aug 3, 2015 12:50 PM
