Oil Leak after changing o-rings
Old Aug 31, 2011 | 06:24 PM
StylinzMax's Avatar
What sup guys I recently changed the o-rings between the block and the oil pan but I still have an oil leak happening it drips when I put the car in park am I fixing the wrong part? because I have changed these o-rings twice and it still leaks in the same area hope someone can help me out thank you.
Old Aug 31, 2011 | 09:31 PM
asand1's Avatar
Only when you shift to park? Sounds like a transmission problem. I'm assuming you were talking about the engines' oil pan.
Old Aug 31, 2011 | 10:10 PM
DennisMik's Avatar
If the oil drips on the ground in the vicinity of the oil filter, it could be that your valve cover gasket is leaking.
Old Sep 1, 2011 | 04:52 AM
StylinzMax's Avatar
its leak right underneath the lower block where i replaced the seals
Old Sep 1, 2011 | 04:53 AM
StylinzMax's Avatar
thanks i replaced that already I'm thinking if its the rear main seal?
Old Sep 1, 2011 | 06:54 AM
asand1's Avatar
Idk what seals u replaced. Is it only with the trans in park?
Old Sep 1, 2011 | 07:54 AM
asand1's Avatar
Old Sep 1, 2011 | 12:03 PM
DennisMik's Avatar
We need more info.
Were the seals you replaced on the transmission oil pan or the engine oil pan?
Is the oil leak on the driver's side or the passenger side?
Is the oil red like transmission oil or blackish like used engine oil?
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
seesole
Sep 14, 2015 12:38 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
