noise/vibration when steering turned all the way...power steering issue?
Old Sep 3, 2011 | 06:56 PM
tarun900's Avatar
Ran into this issue tonight out of the blue. This occurred when car is parked....I didn't notice it while driving, so issue might be there, not sure. When I turned the steering all the way to the left and all the way to the right, there was some grinding noise or something....can't really describe it. Some kind of weird noise...I opened the hood, and I think power steering fluid might be low...it was definitely below the "low" marker. The weird part is, I've had a leak for a while and got it fixed last fall. Why the hell is it leaking again? Is the leak what caused the grinding/vibration/whining? I held the steering (although it felt like it wanted to shake it back and forth) tight and after like 3 seconds, the vibration/grinding stopped.
Anyone got a clue?
Any help is appreciated!
Old Sep 3, 2011 | 07:24 PM
Trini Boom's Avatar
Leak is occuring probably around the hoses attached to the pump. Inspect and fix the problem. That sound will occur when it is low but you have to fix the leak first.
Old Sep 4, 2011 | 08:49 AM
tarun900's Avatar
But what about the grinding/intense vibration when I first turned it all the way to the left/right? It went away after like 4 or 5 seconds. Do you think my power steering pump is on its way out?
Old Sep 4, 2011 | 11:26 AM
asand1's Avatar
Hydraulic systems don't like air. What you are hearing is a hydraulic pump going dry. Fix the damn leak and refill. If you keep running it dry it WILL be toast.
trasmadean
Feb 1, 2017 08:20 PM
Andy29
Aug 31, 2015 01:59 PM
hydriplex
Aug 28, 2015 02:13 PM
tnewbs
Aug 28, 2015 10:15 AM
jhontelj
Aug 17, 2015 04:07 AM
